Crank End Play - Chevy 350 - Team Camaro Tech
Thread Tools Display Modes
Old Feb 25th, 08, 02:18 PM
tim68rsss tim68rsss is offline
Default Crank End Play - Chevy 350
What is the acceptable range of crank end play for a freshly rebuilt 350, has not been cranked? Engine has stock crank and rods with standard size bearings. Plan on using a dial indicator to measure end play. Thanks!
1968 RSSS BB 396/325 AC TH-400 Black/Red (Sold)
1969 Nova SS 350 M-20 Red/Black (Original)
1967 Chevelle SS (Clone)(Project)
Old Feb 25th, 08, 02:35 PM
Badbird's Avatar
Badbird Badbird is offline
Banned
Ron
Default Re: Crank End Play - Chevy 350
The Shaft End-Play for a 350 is: .003-.011....Beginning in 1970, it was reduced to: .002-.006
Old Feb 25th, 08, 03:30 PM
Thanks Ron!
Old Feb 25th, 08, 05:02 PM
Badbird's Avatar
Banned
Ron
Originally Posted by tim68rsss View Post
Thanks Ron!
You're Welcome!
Old Feb 27th, 08, 04:43 PM
Checked with a dial indicator and had 0.005 then turned the motor and measured 0.006. Looks like it should be okay.
Thanks for the input!
Old Feb 27th, 08, 05:07 PM
Badbird's Avatar
Banned
Ron
That's an excellent measurement!.....It's best to be on the low side rather than the high side!
Old Feb 28th, 08, 06:02 AM
zdld17 zdld17 is offline
Don
Sometimes too much or too little endplay will show up, Make sure thrust bearing and main cap are seated well and against the crank flange. You can loosen the main cap some and tap balancer end of crank with soft mallet or wooden hammer to seat thrust flange against the thrust bearing surface. Retighten and torque, check again.
Don
TC # 349
Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E
http://s102.photobucket.com/albums/m...t=115_1577.jpg
Old Feb 28th, 08, 10:22 AM
I checked the end play during assembly with feeler gauge and it measured about 0.007. The engine is all together now and I checked it with dial indicator and it was 0.006.
Old Dec 13th, 14, 02:56 PM
Danjahill Danjahill is offline
Is the end play the same on a 96 vortex??
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: Crank End Play - Chevy 350
Location
Location
First Name
Human Verification
