| Team Camaro Tech Current Topic: 700r4 trouble | ||
just installed 700r4,all gears egage they are weak but they engage ,but no reverse,any advice?
| Sponsored Links | ||
Advertisement | ||
How did you set the TV cable adjustment? Is this a newly built trans or a known good used unit?
Do you have enough fluid in it?
1968 RS/SS with a bunch of stuff done to it that I like... |
You'll want to raise the rear end on jack stands during the fill. Cycle through the gears to purge all the air out. You'll have to be pretty agressive on the brake to stop the wheels before changing directions though. You'll probably have to top off the transmission at least once or twice until it's hot and full. Remember each mark is 1 pint (1/2 quart).
Throttle Valve Cable adjustment is very important on a 700R4. You can do damage to the tranny if its not right. If the TV adjustment is ok and fluid is ok, then the tranny is suspect IMHO. Has the pan been off? Is the filter installed...correctly?
Dave ======================== 68 Coupe, 350 w/ Edelbrock Performer RPM heads, cam, intake, 700R4, Dave's small body HEI |
thank you for your help,also,i never disconnected the tv from the throttle body how do i adjust it?
If the TV is not adjusted correctly, you can damage it pretty good upon start-up I think.
Steve 67 Camaro RS
| Sponsored Links | |
Advertisement | |
