BBC head comparison....781's -vs- 049's - Team Camaro Tech
Thread Tools Display Modes
Old Mar 5th, 08, 07:01 PM
dubs68camaro dubs68camaro is offline
Default BBC head comparison....781's -vs- 049's
Getting ready to do that RV cam swap in my tow vehicle that you guys helped me with. It's a '73 454. When I popped the valve covers, I was sure I was going to find the old 781's that I always seem to see on a 454. Instead, I found '73 049's. Couldn't really find much on stan weiss's site and mortec just listed the 781's with 118cc chamber, 256/114cc ports and the 049's with 122cc chamber, 255/119cc ports. Except for the chamber cc difference, are these heads basically the same, or is there a chance that the 049's are a better head? Don't they both have 2.06/1.72 valves?
I'm asking because if the 049's are for some reason a better flowing head, I'd rather swap with my extra 781's and use the 049's for an up in coming project that's going to have a much bigger cam. Any thoughts in always appreciated! thanks
Old Mar 5th, 08, 08:27 PM
AXEMAN39 AXEMAN39 is offline
Scott
Default Re: BBC head comparison....781's -vs- 049's
The 781 and the 049 are virtually identical, both great heads. They like bigger valves 2.19 & 1.88 and a little bowl work Lots of the guys at Team Chevelle run 10s with these heads.
Old Mar 5th, 08, 08:35 PM
I did a little bit more research and found a website that had a flow chart. They claimed that the 049's flowed the best out of the 3 early large oval heads. They also said, like you, that they like a 2.19/1.88 valve arrangement. Thanks!
Old Mar 5th, 08, 08:45 PM
Scott
If you want more info on them just go over to the team Chevelle site and do a search seems like 3/4 of the guys over there are running big blocks!
Old Mar 5th, 08, 09:51 PM
Travis1 Travis1 is offline
Travis
I have ran both heads. I found that the 781 being an open chamber, made better power than the 049. With both motors having flat top pistons. The 049 gave me a bit more compression, but the 781 motor ran 3 to 4 tenth better in the 1/4 mile.
Old Mar 6th, 08, 02:30 PM
pdq67 pdq67 is offline
Banned
WOW!
A flat-top pistoned 454 w/ either heads and .020" thick shims will be down in the 7.9 to 8 to 1 CR. range imho.. No higher than 8.5!
And you have to cc the suckers to REALLY know what your CR. is going to be!!!!!!
pdq67
Old Mar 6th, 08, 03:21 PM
Travis
With the 781s it had 9.1 with the 049 it had 10.3. And yes with flat tops. I had alot of fun with both. weeeeeeeeeee
Old Mar 6th, 08, 03:45 PM
How could it have had more compression with the 049's when they are 122cc and the 781's are 118cc????
Old Mar 6th, 08, 04:23 PM
Travis
The set I had the 781s were 119cc and the 049 were 98cc I had them
cc'ed by a local shop. That was the numbers they gave me. The 049s were milled 30.
Old Mar 6th, 08, 07:52 PM
Busted Knuckles Busted Knuckles is offline
Travis, are you sure you have the casting numbers right? Both 781's and 049's are open chamber and they're virtually identical. Sounds like the ones you're calling 049's are a closed chamber head.
Gary Adrian
FCS Harmony Racing
Momma always told me not to look into the eyes of the sun.
"But momma, that's where the fun is!"
  #11
Old Mar 6th, 08, 08:38 PM
Travis
Gary you are right, I must have had my numbers wrong. I apologize for any wrong info I may have given on this thread. I did have 781s, but I also had a set of closed chamber big oval, that were eather 702s or 802s that I (thought) were 049.
Thanks for the corect info..This site will keep you on your toes.
  #12
Old Mar 6th, 08, 09:33 PM
Oh great Travis....because of your mis-information, I just traded my 049 heads for a set of spark plugs!!!!! Now what should I do?????
I have the 702's on my 460 and they work quite well. I don't mind the open chambers on the 049's because it will allow me to piston match my next build to get the exact CR I want. Thanks guys.
  #13
Old Mar 7th, 08, 04:58 AM
[QUOTE=dubs68camaro;954294]Oh great Travis....because of your mis-information, I just traded my 049 heads for a set of spark plugs!!!!! Now what should I do?????
ROTFLMAO!!!
I actually have a very nice pair of 702's that have had bronze guides installed and have been cut for bigger valves with the valve job roughed in. I'm trying to figure out what to do with 'em, don't have any current 454/496 projects...do you think I could maybe swap 'em for one of those cool little hula girls for my dashboard???
Gary Adrian
FCS Harmony Racing
  #14
Old Mar 7th, 08, 03:07 PM
bigblock chev bigblock chev is offline
pat
my 781s got 2.30 1.90 valves and flow 365@700 lift they work.
  #15
Old Mar 7th, 08, 08:40 PM
Travis
I am sorry about the sparkplug thing. If we meetup at a show, I'll buy you a beer. The heads I had were 702. I still think the 781s are a better head. They make good power up to about 7000. Thats just my (OPINION).....
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: BBC head comparison....781's -vs- 049's
Location
Location
First Name
Human Verification
