Where can I get solder plugs to fill holes in sheetmetal? - Team Camaro Tech
Body Shop Paint & Body Forum
Old Nov 23rd, 00, 10:43 PM
Allen M Allen M is offline
Question
I've used these solder plugs before to fill in holes, but I don't know who sells them. I know Eastwood doesn't sell then.
If you've never seen them, they're great. They're little solder plugs that come in different sizes. If you want to fill a drilled hole, emblem, or any hole, all you have to do is get it to bare metal, use a little tinning acid, then find the right size plug. Using a fine torch or heavy duty soldering iron, melt the edges of the plug and then file smooth. With this set up, the metal doesn't warp, and if you wanted put the emblems back, a little heat and the plugs are gone.
Now.... only if I can find out where to get them!!!!
Old Nov 24th, 00, 03:30 AM
ragtopman ragtopman is offline
Jim
Post
Have you ever used acid core solder? Works pretty much the same way.
67 Camaro SS Conv.
70 Challenger R/T Conv.
Old Nov 24th, 00, 08:37 AM
Post
Ragtopman,
Yes, on smaller hole. The plugs are nice and a lot faster for hole larger than 3/8" on really thin metal. Several of my freinds are looking for it too.
Old Nov 29th, 00, 05:28 PM
Post
I take it no one knows where to get the plugs?!?
