GM 572 Crate Motor...is it streetable? - Team Camaro Tech
Thread Tools Display Modes
Old Mar 16th, 08, 09:41 AM
funbnme funbnme is offline
Dan
Default GM 572 Crate Motor...is it streetable?
Can this motor be installed in a 68 Camaro that would have aftermarket A/C and a 4 speed and be a streetable car?
By streetable, I mean being able to cruise casually and leave stoplights without feeling like you're riding a bucking bronco.
Anyone have this engine in their Camaro?
Dan
1968 RS - Black
408 w/ Muncie 4 speed & 12 bolt rear
Deluxe Houndstooth Interior
Dropped 2" with TeamIII Mini-Lites
Click for Picture:
http://i26.photobucket.com/albums/c1...roGrocery4.jpg
Old Mar 16th, 08, 12:50 PM
BigBlock1969RS's Avatar
BigBlock1969RS BigBlock1969RS is offline
Ed
Default Re: GM 572 Crate Motor...is it streetable?
Are you talking about the 600hp version or the 700? I believe the 600 will run on pump gas while the 700 needs race gas.
I would think with the right rear end gear and some meaty tires you could control it from a stop, just have to train your foot
Old Mar 16th, 08, 01:22 PM
wiskeesour's Avatar
wiskeesour wiskeesour is offline
Harley
The 620HP is plenty streetable...if you dont mind the fact that you have 620HP on tap. Literally on TAP. Unless youve ever had something like that, it aint THAT streetable.
JMHO of course.
AE2(AW) Harley Moody, USNavy
"Master-at-Arms" for the CDWJB!!
November 26th, 2008 was my last day to serve my country as a member of the World's Greatest Navy.
Thanks Chief.
Old Mar 16th, 08, 02:23 PM
guccieng guccieng is offline
the pricetag isn't!
Old Mar 16th, 08, 03:23 PM
JimM JimM is offline
Jim
These are tall decks, aren't they?
You do need to be aware of fitment problems. A tall deck motor is both taller and wider then a standard mark 4. Hood, steering box, and brake booster clearance can be problematic, specific headers may be needed. Accessory drive systems are affected.
All of this stuff can be overcome by thorough planning and buying the right parts. Lack of planning will result in lots of cursing and lots of money spent twice.
Old Mar 16th, 08, 03:33 PM
BelAirBob BelAirBob is offline
Bob
You are absolutely correct sir!
My tall deck 540 needed custom headers,custom accessory drives,etc. If I had it to do over, build a 9.8 inch deck height 502 or 540. They will run just as well will alot less headaches,and for less $ I might add.
Speedomotive has an all ALUMINUM 572, 700 HP on pump gas for about $15K. Yes, it is a bunch of cash,but when you can have an aluminum block with 100HP more for just a little extra, its a much better value. They also have more economical short-deck engines in steel or aluminum.
More power, less weight, less hassles than the 572 crate. (hey it rhymes! )
BelAir Bob
69 Z28 X33 D80 Dusk Blue
69 Z28 X33 Rally Green
http://www.belairbobs.com
Old Mar 16th, 08, 04:33 PM
prostock prostock is offline
Bubba
i have put alot of tall decks in camaros, trucks, nova's, and one corvette, never had to have any headers made just used what we had, the deck is .400 taller. if something is in the way of your big new 572 you trim it. and yea you can put the creature comfort stuff on em, a/c p/s , have buddy w/600 ci engine w/air p/s etc in a steet car w/ 880hp and he has two NOS kits on it just in case he is late for work.
Old Mar 16th, 08, 09:42 PM
Straight-line-69 Straight-line-69 is offline
The bigger question,..is the car set up for 600 hp? Most everything in the drivetrain, from the flywheel to the axles and lug studs, need to upgraded. The HP is the easy part,..setting up the car to take it is another (expensive) story.
Also, if you're running a Muncie and sticky tires, you will puke transmission parts with that kind of HP and torque.
But it sounds like a fun project,..good lucK!
Old Mar 17th, 08, 08:49 PM
Bubba
be bold man, swim the river,jump the ditch, do something that others wouldn't. thats how some dude found america, were here ain't we!
Old Mar 18th, 08, 01:59 AM
BlackoutSteve BlackoutSteve is offline
Steve
Buy the 720 and water inject it so you can use pump gas.
Have your cake and eat it too!
The Speedomotive 572 sounds interesting.
Nov 68 Van Nuys. 327 floor-shift-auto, Frost Green and not much else when new.
http://img233.imageshack.us/img233/3...sychedelic.jpg
http://www.usmuscle.com.au/Forum/showthread.php?t=2840
  #11
Old Mar 18th, 08, 05:10 AM
Everett#2390's Avatar
<Jake-68's rule
Convert to forward mounted power steering rack to gain more space and carry a big club to gain more room.
Six hundred horsepower will find the weakest link. Hopefully, it will be the tires.........
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: GM 572 Crate Motor...is it streetable?
Location
Location
First Name
Human Verification
