| Team Camaro Tech Current Topic: finally pulled the old motor | ||
| Engine General Engine Discussion. |
heres some pics of the motor pulling
Now time to detail the engine bay before the new motor goes in. for those that havent seen the new motor (chevy 406) here it is |
| Sponsored Links | ||
Advertisement | ||
68 camaro, 350 vortec heads, rpm air gap, lunati voodoo cam, coated headers, th350, 100 shot, 3.73, eaton posi. http://www.dropshots.com/justincat#a...03-26/05:22:38 http://www.dropshots.com/justincat#a...02-28/06:00:23 |
Lets get some specs on the pretty 406!
69 Camaro 491/AFR 315'S/XR286R TH400/GV OD 9" 3.50 |
509 chevy 400 block
splayed mains Brodix SPCH heads (spec. heads) 2:06 intake 1:90 exh Wisco forged flattop pistons jet titanium rods 5.7 "(older reconditioned) Cola forged crank (ext balanced) Isky Racing Cams Hydraulic roller tappet RPM Range: 3,000-7,000 Intake Duration at 050 inch Lift: 238 Exhaust Duration at 050 inch Lift: 248 Duration at 050 inch Lift: 238 int./248 exh. Lobe Separation (degrees): 110 Grind Number: RR-284/294 Milodon oil pan with scraper super victor intake AED 850 cfm DP carb |
| Sponsored Links | |
Advertisement | |
