How to carefully start an old engine? - Team Camaro Tech
Thread Tools Display Modes
Old Mar 18th, 08, 10:52 AM
z28clone z28clone is offline
Default How to carefully start an old engine?
69 Camaro, 307, its been sitting awhile. Would like to start the engine, what is the proper procedure to start an engine that hasnt been started in a long time, wd40 in cylinders, etc. Any help would be great!
Old Mar 18th, 08, 11:00 AM
dawg's Avatar
dawg dawg is offline
Harry
Default Re: How to carefully start an old engine?
change gas
change oil and filter.
drain fuel bowls
prelube engine if you can
Dawgs 69
434 stroker
US Navy retired
http://www.northeastf-bodyassn.com/
Old Mar 18th, 08, 11:29 AM
zdld17 zdld17 is offline
Don
Remove plugs and add a few oz of Marvel oil, let it soak, then spin motor to blow out.
Don
TC # 349
Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E
http://s102.photobucket.com/albums/m...t=115_1577.jpg
Old Mar 18th, 08, 11:40 AM
68Lemans blue 68Lemans blue is offline
Jerome
No wd40 ,do as Dawg stated ,if you can't prime engine a little lube can be added to each hole try to spin engine manually ,put plugs in then crank 10 to 15 seconds with no power to ingnition ,then go for it ...Happy Motoring I hope for you
Old Mar 18th, 08, 02:11 PM
dnult dnult is offline
In addition to the above suggestions, cranking the engine with the plugs out is a good idea.
Dave
68 Coupe, 350 w/ Edelbrock Performer RPM heads, cam, intake, 700R4, Dave's small body HEI
Old Mar 18th, 08, 05:33 PM
prostock prostock is offline
Bubba
remove plugs first thing, this will let you lube it w/ marvel or atf and it will let water or oil etc out without bending a rod, you should spin the starter until you hear the motor pickup oil pres then spin it till you think it filled the push rods, maybe 3-4 10 sec spins, i do the finger over the plug hole test to see if theres a dead hole while its spinnin. have battery charger hooked up. follow all other directions in other post and you got it. good luck, worn the nieghbors about smoke bomb in advance. hope this will be outside when she fires. lol.
Old Mar 18th, 08, 08:33 PM
77wolf10.85's Avatar
77wolf10.85 77wolf10.85 is offline
Tim
The oilfield is so desperate for engines anymore that I haven't seen a pickled engine in over 10 years. But I've started many an engine that has been in storage 10 or 20 years. They can't tell time, all they know is fuel, fire and compression. Do what everybody is telling you...prelubing, cranking with plugs out, oil in cyls. Let your ears tell you if everything is ok and then go for it.
I wish I had time to tell the story of the 49 I started that had Zero compression. Took 3 days to free it up and half a day to start. I was brutally mean to that thing. Named it Smokey. And it would smoke the tires too. 49 chevy pu frame and engine and tranny. After I got it started and we quit laughin our *** off I stood up on it and put it in gear, let the clutch out and it just spun heck out of the tires, I just let it sit there and spin laughed so hard I fell off the damthing and it just sat there bellerin smoke from both ends. I guess I did have time to tell about it.
Edit: 1 thing you'd probly do anyway but I don't recall seeing posted.... turn it through by hand first
Tim Smith
Old Mar 19th, 08, 07:29 AM
dubs68camaro dubs68camaro is offline
Heck.....all I was going to suggest was Viagra or Cialis!!!
Old Mar 19th, 08, 04:29 PM
pdq67 pdq67 is offline
Banned
And don't be afraid to hammer her hard if she won't run right, right offthe bat b/c sometime's they need hammered to straighten out their suck!
So then they get fuel right and will idle right along once the temp come's up!
In other word's gently BLOW HER OUT AT RPM!! And let her come down to a fast idle AND then tune her!!
AND, imho, good old MMO is MADE for this!!
I've used it several times through the years and one time in particular, one engine was bone ring/valves dry and had NO compression, but MMO fixed that fast!!
pdq67
Old Mar 19th, 08, 04:38 PM
WILMASBOYL78 WILMASBOYL78 is offline
Tech Team
Smile Re: How to carefully start an old engine?
Make sure you have a fire extinguisher handy....
wilma
02 Berger 380hp 6spd red/white conv/Lots of L78 Novas.....69 SS350 Camaro..Karen's new addition!
  #11
Old Mar 20th, 08, 05:28 AM
GreyShadows GreyShadows is offline
Kyle
I don't think anyone has stated that you should roll the engine over by hand a few strokes to make sure everything moves .. not with starter or at least thats what i used to do.
1969 Z/28 CLONE 350
4 SPD MUNCIE,
4 WHEEL DISK BRAKES,
4:11 POSI
BLUE W/WHITE STRIPES
http://www2.snapfish.com/slideshow/A...71/t_=88171671
  #12
Old Mar 20th, 08, 06:41 PM
Banned
Right!! Roll her over by hand a couple a turns by the crank bolt or using the belts the hard way!!
And I always have a water hose handy w/ the rad. cap loose too in case she heats up before she normalizes!!
pdq67
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: How to carefully start an old engine?
Location
Location
First Name
Human Verification
