396/375 hp BBC engine value? L78 - Team Camaro Tech
What's it worth? & ebay discussions
Thread Tools Display Modes
Old Mar 19th, 08, 10:44 AM
rogue rogue is offline
Default 396/375 hp BBC engine value? L78
I am selling the complete 396ci engine carb to pan from my Camaro and have no idea what it is worth. I am dropping in a new motor.
It is a 396/375 hp block with mild wolverine cam, velonia pistons, and edelbrock thunder 800 carb, stock chevrolet manifold and heads. Engine runs strong and is being sold while still in car. I have all receipts on the build, and documentation. Motor was built less than 10k miles ago. Block has code "TO724JH"
Any ideas on what a fair price would be?
Old Mar 19th, 08, 05:05 PM
Default Re: 396/350hp BBC engine value?
Anyone?
Old Mar 19th, 08, 06:45 PM
Heatman Heatman is offline
Tech Team
Stephen
Fair price.
Old Mar 19th, 08, 07:09 PM
jd502 jd502 is offline
What heads are on it. That sounds cheap to me especially being able to hear and see run. i would thing you should be able to get 2500.00 pretty quick.
Old Mar 19th, 08, 07:21 PM
martins 68 martins 68 is offline
sounds very reasonable If you were close Id give you 1800.00 easy
1968 camaro ss gold/gold
2003 dodge 1500 hemi
2007 yukon denali
2004 kfx vforce 0-60 3 seconds
2002 660 grizzly
Old Mar 19th, 08, 07:57 PM
68Baldwin 68Baldwin is offline
$1800.00 is extremely fair....Whats the casting numbers on the heads and block? Date codes? Cam specs? Compression?
Old Mar 19th, 08, 09:26 PM
Default Re: 396/375hp BBC engine value? JH Code block
Block stamping says T0724JH
According to the guide that means this is a 396 375hp block from a 69 Camaro or Chevy II am I right?
L78?
I've yanked the Craigslist ad until I find out out what the story is with this setup
Old Mar 19th, 08, 09:49 PM
bertfam bertfam is offline
Ed
Default Re: 396/375 hp BBC engine value? Block code JH
Is this the original engine for your car?? If so, you may want to re-think selling it!
Ed
Ed
My car is a 69 Z28, the DZ block is long gone and it was converted to a BBC car two owners ago.
Old Mar 19th, 08, 10:26 PM
July 24 1969 JH,nice!! Post the vin number,the vin will be down by the oil filter.I see you edited the original 396/350 post to say 396/375 .If thats true,4 bolt mains,11 to 1,forged steel crank,840 heads,motors worth way more then $1800.00!! Hell my machine work alone on one of my BB motors was way more then that.
  #11
Old Mar 19th, 08, 10:28 PM
According to all the documentation I have, compression is 10.5:1 with the velonia pistons. I've got a pretty extensive file on the build. I need to pop off the valve cover to identify the heads I guess. Intake is original snowflake.
  #12
Old Mar 20th, 08, 03:13 AM
Unreal Unreal is offline
Gary
I thought I had lost it...Originally you said 350hp, and I thought your pricing was low, but not way off. (figured you were looking for quick sale)
L-78 is a whole new ball game. A set of 840 heads is worth $ 1500-2000. JH block is worth $1500, 6221 crank is worth $300, 163 intake is worth $300.
Add to that you have a rebuild, running engine, and I'd say it's worth $5k.
PS JH is for L78 w/manual tranny
  #13
Old Mar 20th, 08, 06:14 AM
Erik Beckett Erik Beckett is offline
Default Re: 396/375 hp BBC engine value? L78
Rogue, I sent you a PM>
Erik
67 Camaro Pro Street, 540 Bill Mitchell Merlin big block, Merlin Aluminum heads, Holley 870, hydraulic camshaft, 2" Hooker Super Comp headers, Mallory and Crane ignition system, TH400, 2600 stahl, Ford 9" w/ 4:10 gears and posi.
  #14
Old Mar 20th, 08, 10:36 AM
Thanks for the numbers. Looking around on ebay looks like you're spot on.
Seems theres a lot of guys asking some outrageous amounts for the blocks as well. $3500 just for a block
  #15
Old Mar 20th, 08, 05:23 PM
Didn't this post say 350 hp originally? I just sold a set of 840 on ebay for 1400.00 I would say that is a deal at 2500.00 if it is a 375 hp jh motor.
Team Camaro Tech > All Generations > What's it worth?      Current Topic: 396/375 hp BBC engine value? L78
Location
Location
First Name
Human Verification
