Whaddya think...3.73 sound about right? - Team Camaro Tech
Old Mar 20th, 08, 01:40 PM
edhjohnb edhjohnb is offline
JB
Default Whaddya think...3.73 sound about right?
Hi Guys,
I just got an Auburn limited slip differential and Moser axles to upgrade my current stock 67 RS 10-bolt rear end. The car has a slightly modified 327 and a TH 350 tranny with a shift kit. I want something that isn't going to rev too high at highway speeds, but still give me some performance. I was thinking about going with a 3.73 gear ratio...does that sound about right to you guys?
Thanks for your opinions,
John
1967 Marina Blue RS Coupe: http://i124.photobucket.com/albums/p...S/IMG_2672.jpg
2011 Red Jewel Tintcoat RS Convertible: http://i124.photobucket.com/albums/p...e/IMG_0398.jpg
1967 Madeira Maroon Coupe (barn find): http://i124.photobucket.com/albums/p...d/IMG_0107.jpg
Old Mar 20th, 08, 02:20 PM
mbrekke's Avatar
mbrekke mbrekke is offline
Mark
Default Re: Whaddya think...3.73 sound about right?
3.73's may be a bit much for the highway without OD. Depends on your personal preference, but you may be happier with something in the 3.23-3.42 range if you do a lot of highway driving.
Here's a calculator. You can play with different gear ratios and see what you like.
http://www.ringpinion.com/Calc_RPM.aspx
Mark
'68 327 4-speed 3.42 posi and a sunroof
best so far... 13.25 at 106mph
'78 Firebird 350/T350 3.23 posi
'65 Mustang convert. 6 cyl. 3-speed
'66 Mustang coupe 6 cyl. auto
http://www.camaros.net/forums/member.php?u=3230
Old Mar 20th, 08, 03:39 PM
mnm99's Avatar
mnm99 mnm99 is offline
Marc
3:73's with a turbo 350 were too much for me on the highway. I Have 3:25's now and love them. You can either get 3:08's or 3:31's I believe.
1968 Camaro Convertible ,350 TWIN TURBO , PTC 3000 stall, Hotchkis TVS kit / Subframe connectors, Caltracs, 9" rear, Street Star wheels (P275/40ZR17 / P235/45/17) , Electric cutouts. [B]
Old Mar 20th, 08, 03:56 PM
mike p mike p is offline
I would go 3.08, 3.36, or 3.55 with stock 10 bolt, depending on tire height. I wouldn't do 3.73 unless I switched to 2004R transmissin. I have 26.1" tire.
1968 327 sport coupe. Son of original owner.
Old Mar 20th, 08, 03:57 PM
dawg's Avatar
dawg dawg is offline
Harry
I have a 3:73 ratio and TH350 and it seems good on the hiway.
rpms about 3100 (at 65 mph)
So as long as your not running 75 etc. youll be fine.
or if you want lower RPMs at highway speeds go with a 3:55 gear its the best of both worlds.
Dawgs 69
406 stroker
us navy retired
http://www.northeastf-bodyassn.com/
Old Mar 20th, 08, 07:09 PM
DOUG G DOUG G is offline
RedЯuM
Mine runs about 3000ish @ 65 with 28" tall tires and 3.73's. (Not an overdrive trans.)
68 Camaro~ LSx
RedЯum <-Pics
http://www.youtube.com/watch?v=Of8WV...ature=youtu.be <~More here
Old Mar 21st, 08, 04:36 PM
pdq67 pdq67 is offline
Banned
I dearly lOVE my stock 3.31 posi-, 12-bolt gears and I bet you will like stock, 3.36, 10-bolt gears!!
I'm not talking about 8.5" rearends here.
pdq67
Old Mar 21st, 08, 08:06 PM
JB
Well I think I've decided to compromise...I think I'm going to go with 3.55 gears to help reduce highway speed RPM but still have a little pop.
Thanks for all the great advice guys!
