newbie needs some help - Team Camaro Tech
Tag Team De-coding tags and numbers.
Old Mar 23rd, 08, 09:59 AM
509BBCamaro 509BBCamaro is offline
David
Default newbie needs some help
I have a 1969 camaro with a big block now, has a th400 but has a factory clutch pedal, date correct 12 bolt( I have to recheck what the ratio is) multi leaf rear. Anyway my question is I have already decoded the trim tag and in the bottom right corner where the exterior trim code is it has H430. From what I have found that just means what day and what number car it was for that day. Is there any other way of finding out what the car came with without the build sheet? here is the vin and trim code
124379L529137
VN318818
TR 711 71 71
04B H430
bottom line is I just need some help!! Thanks
1969 Camaro. BBC. TH400. 12 bolt. Original steel. Original interior.
Old Mar 24th, 08, 07:49 AM
click's Avatar
click click is offline
Moderator .. Jim
Jim
Default Re: newbie needs some help
Sorry to say David, no. The trim tag and VIN wont help you decode the car's original options. Have you dropped the gas tank? LA built cars had a broadcast sheet that was placed on top of the tank as it was installed under the trunk. ONLY LA cars had this done and if the tank is original, it might still be there. That has a list of options the car was born with. If its there, be VERY careful removing it. Take pics of it in place before attempting to remove it, it might fall to pieces.
Click..is Jim..former owner of a 69RS-LM1 350/255 - 700r
Photos for viewing
Learn How To Post Pics here
Old Mar 24th, 08, 06:48 PM
David
thanks for the reply, unfortunatly the tank has been dropped with no success in finding the build sheet
Old Mar 24th, 08, 08:11 PM
Kurt S Kurt S is offline
What's the complete axle code?
1 or 2 fuel lines?
Kurt S.
CRG - www.camaros.org
