67 camaro hotchkis upgrade - Team Camaro Tech
Camaro Tech General Tech Area
Old Apr 2nd, 08, 05:07 AM
67rscoupe 67rscoupe is offline
Rudy
Default 67 camaro hotchkis upgrade
Hi all, Im sure this topic has come up many times however i need some help. I have have a 67 camaro with stock mono leaf springs i just purchased hotchkis real multi leafs. I have on the car now on the rear 17x9.5 rims with a 5.5 back space and I AM GETTING wheel rub. Im not sure if its because the monos i have now are just to worn and it is creating body roll. Or i just bought rims to big. Has anyone on this site with the same wheel size install hotchkis on there car? im curious about wheel rub. Can anyone help.
Old Apr 2nd, 08, 05:41 AM
DjD's Avatar
DjD DjD is offline
Dennis
Default Re: 67 camaro hotchkis upgrade
what size tires you got on your wheels?
...Dennis
White Wonder
The Nova
Photo Album
www.camaroslimited.com
Old Apr 2nd, 08, 07:04 AM
Rudy
They are 275x40x17
Old Apr 2nd, 08, 07:39 AM
DjD's Avatar
DjD DjD is offline
Dennis
That's about as large as would fit on a '69 coupe and would more than likely scrub unless the suspension was perfect. In your '67 it's my understanding you don't have as deep of a wheel well so you would want less backspacing on the wheels. This would mean you don't want the wheel well lip coming down on the tire though.
The Hotchkis springs may not drop the car much if the orig monos are in bad shape, you'll loose some body roll but with that size tire you're asking for a bit of scrubbing, just depends on where it is (inside or outside of tire) and how much is acceptable to you. I carry passangers and a full trunk a lot so I ate the cost of a set of 275/40's and replaced them with 245/45's on my ragtop. Tread width is almost the same, there is an inch less overall width at the sidewall and just a bit more rubber between the rim of the wheel and the ground. Off the car the 275's looked much bigger than the 245's but mounted on the same wheel you hardly notice the difference. Check the sizes on the tire rack site or check the links provided in the stickie tire thread in wheel and tire for sizing info.
...Dennis
White Wonder
The Nova
Photo Album
Old Apr 2nd, 08, 08:57 AM
Fred Ficarra Fred Ficarra is offline
Fred
Just to jump-in too; not sure of a 67 but on my 69, 4.5" backspacing is the limit regardless of tires or wheel diameter.
One owner 69 Camaro,(yep, bought it new)
RS SS Hugger Orange, L88, 4:10's tru-tack posi, ducted hood, Endura, spoilers.
TH400 (CX) GV with Coan 8" converter, GV-OD, 8 track still on console and best et 10.617, 126.45mph 1.478 60'
All with 1960's stuff. (except tires and converter)
+ MT Super Scavenger headers.
1000cfm AED and HD Harold-Lunati SR, 725 lift with shaft rockers too.
http://epitomesrebuild.com/
Old Apr 2nd, 08, 09:02 AM
DjD's Avatar
DjD DjD is offline
Dennis
funny Fred I ran 15x8's with 5" bs and now run 17x9.5" with 5.5" back spacing... Why do you say 4.5" is the limit? my 9.5" would be into the fender lip with 4.5" bs...
...Dennis
White Wonder
The Nova
Photo Album
Old Apr 2nd, 08, 09:16 AM
LCAC_Man LCAC_Man is offline
Len Barron
I've got 275/50/17's on my 67 with hotchkis rear springs.
The backspacing needs to be perfect to center a tire of that size in the wheel well. You didn't say whether you were rubbing on the inside or outside, if outside than the higher rate hotchkis springs will likely help, though not completely eliminate the problem. If rubbing is on the inside than some 1/8" spacers may solve your problem.
My rear wheels are 17x8 with 5.25" backspacing, I used an 1/8" spacer on one side and a 3/16" spacer on the other to center the tires in the wells, the rear axles are rarely centered perfectly in the chassis. I measured my car 3 or 4 times before I ordered my wheels and intentionally got wheels with more backspacing than I needed to allow the flexibility I wanted.
Len
67 SS-350 Convert.
406/200r4/12b 3.73's Truetrac
Len's PT Garage
Old Apr 2nd, 08, 09:21 AM
Fred
Dennis, I sure don't do this stuff every day. Bought my Centerlines back in the mid 80's. The Gatorbacks at the same time. Last year I looked for cheap wheels for a set of drag tires. My Centerlines sure look to be as close to the inner wheel well panel as possible without letting the sidewall rub. But it's only an eyeball evaluation. But I do remember reading something online (somewhere??) that said 4.5" BS was the limit. But I cheat when I can. My rear wheel well lips are long gone. And all the fenders are pushed out with a portapower. I like big rubber!
Now looking up at the inner lip, there's room. Maybe I can run bigger stuff! Ya know, those old Gatorbacks are too hard to risk the car on 'recreational speed-cornering'. Maybe it's time for a change. Thanks Dennis!
Old Apr 2nd, 08, 09:26 AM
Rudy
I aprreciate all the responses. The rub is on the inside and it happens when the body is flexed when i am pulling on my driveway ramp. DJD what back spacing do you have on your fronts and what tires size is the front rims?
Old Apr 2nd, 08, 09:33 AM
Fred
Rudy! Is that the only time it happens? Pulling onto your driveway? I sure wouldn't condemn a set or otherwise good rolling stock just for that.
Old Apr 2nd, 08, 09:46 AM
DjD's Avatar
DjD DjD is offline
Dennis
17x8 4.75 backspacing... It's all on the first page of this thread in the wheel and tire forum along with many other combos... http://www.camaros.net/forums/showthread.php?t=100853
Also check this one for some additional good info... http://www.camaros.net/forums/showthread.php?t=33680
...Dennis
White Wonder
The Nova
Photo Album
Old Apr 2nd, 08, 09:47 AM
Rudy
Yeah pretty much thats when the rears rub is when im pulling up the ramp on an angle.
Old Apr 2nd, 08, 10:16 AM
quickboat quickboat is offline
jim
I think the 4.5 inch BS rule is with 8 inch wheels only. As the wheel gets wider the back spacing must be increased. My 8 inch wheels with the 4.5 inch back spacing just barely rub on the inside with 275/60/15 (DOTs)on the back. I have yet to start cutting the quarter lip for bigger rubber but when I do i will need to increase the back spacing to keep the tire from rubbing. Or MINI TUB!!!!
67 RS Deluxe Int. A/C car
TKO-600
400 4 bolt block .03 over
Ported 215 Pro1 Platinums
Forged/balanced 400 crank, pistons, 6" rods
286HR cam w/1.6 rckrs LS1 beehives
15x8 Rallys, Gulstrand, Konis, Eibachs, 1" Swaybar
IROC s/gear, 4 wheel discs
Old Apr 2nd, 08, 11:43 AM
DjD's Avatar
DjD DjD is offline
Dennis
Jim it's the 275 tires not the back spacing being more than 4.5". I ran 245/60/15's on 15x8 5" bs with no scrubbing unless I had 4 in the car and drove into a steep driveway sideways and that was before new springs and subframe connectors. The 275 sidewall buldges the same on either bs it's just a 1/2" further away from the inner fender with the 4.5" bs.
...Dennis
White Wonder
The Nova
Photo Album
Old Apr 2nd, 08, 01:16 PM
davidpozzi davidpozzi is offline
David Pozzi
Rudy,
Do you have the Hotchkis front and rear anti-roll bars on the car?
Check my web page for First Gen Camaro suspension info: http://www.pozziracing.com
67 RS 327 original owner. 1965 Lola T-70
