| Team Camaro Tech Current Topic: 98 Z28 camaro parts into 68 Camaro? | ||
| Camaro Tech General Tech Area For best results use specific forums |
What is usable besides the motor and tranny from a totalled Z28 1998 camaro? I have a 68 camaro and would like to use the brake booster, clutch master cylinder, rack in pinion, etc.
Anyone know off hand whats transferrable?
"Bloodline" 68 Camaro TT LS3 |
| Sponsored Links | ||
Advertisement | ||
Whatever you want to make fit. The 7.5" rearend is weak and it's coil springed, and it is not worth using. Seats, console, and parts of the dash may work with a little fabrication. Engine and trans. can be used. Some of the wheels and tires.
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1 |
I'll add to the above...
- You can adapt the front and rear brakes too. - Unless you '98 clutch master is brand new, you don't want to reuse it. - You do NOT want to convert to rack & pinion (unless you are doing a full Art Morisson subframe which comes with its own rack). - With the engine, you'll want the engine wiring harness, computer, and possibly the underhood fuse/relay box - The radiator and fans can be adapted to the '68 - you might want to use the parking brake handle and cables if you use the 4th gen console
1968 Camaro Convertible - LS1, T56, Hooker longtubes, Autokraft pan & mounts, GM LS7 clutch, Borla ProXS, Moser/Strange/Wilwood 9", Covans dash, UltraLite IIs, Procar Elites, Vintage Air GEN-IV, AGR 12:1 steering, Addco swaybars, Hydratech hydroboost |
One my friends practically "bolted in" seats and console from a 2000 Z into his 67. Looks real clean.
67 Camaro: 454/TH400/4.10 12 bolt. Lots of options: PS/PDB/PW, tilt, tach, gauges and more. K-K + 797Z..... |
| Sponsored Links | |
Advertisement | |
