Tools & Shops Shop Rat HQ
Old Apr 5th, 08, 04:30 PM
98blackburb's Avatar
98blackburb 98blackburb is offline
Gold Member
Alan
Default Tools
I usually don't do this, but this is too good not too pass on to the gearheads that have bloodied thier knuckles on thier Camaro's..........
Subject: FW: Tools
I will have to agree to all the below.
I have more than a passing familiarity with common precision tools. When
I got the information below, I immediately recognized it as being
amazingly accurate.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat
metal bar stock out of your hands so that it smacks you in the chest and
flings your beer across the room, denting the freshly-painted fender
which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under
the workbench with the speed of light. Also removes fingerprints and
hard-earned calluses from fingers in about the time it takes you to say,
Oh sh*t.
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their
holes until you die of old age.
SKILL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of
blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert minor
touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board
principle. It transforms human energy into a crooked, unpredictable
motion, and the more you attempt to influence its course, the more
dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt
heads. If nothing else is available, they can also be used to transfer
intense welding heat to the palm of your hand.
WELDING GLOVES: Heavy duty leather gloves used to prolong the conduction
of intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable
objects in your shop on fire. Also handy for igniting the grease inside
the wheel hub out of which you want to remove a bearing race.
TABLE SAW: A large stationary power tool commonly used to launch wood
projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground
after you have installed your new brake shoes, trapping the jack handle
firmly under the bumper.
EIGHT-FOOT LONG YELLOW PINE 2X4: Used for levering an automobile upward
off of a trapped hydraulic jack handle.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known
drill bit that snaps neatly off in bolt holes thereby ending any
possible future use.
BAND SAW: A large stationary power saw primarily used by most shops to
cut good aluminum sheet into smaller pieces that more easily fit into
the trash can after you cut on the inside of the line instead of the
outside edge.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of
everything you forgot to disconnect.
CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar that
inexplicably has an accurately machined screwdriver tip on the end
opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids
or for opening old-style paper-and-tin oil cans and splashing oil on
your shirt; but can also be used, as the name implies, to strip out
Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to
convert common slotted screws into non-removable screws.
PRY BAR: A tool used to crumple the metal surrounding that clip or
bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is
used as a kind of divining rod to locate the most expensive parts
adjacent to the object we are attempting to hit.
MECHANICS KNIFE: Used to open and slice through the contents of
cardboard cartons delivered to your front door; works particularly well
on contents such as seats, vinyl records, liquids in plastic bottles,
collector magazines , refund checks, and rubber or plastic parts .
Especially useful for slicing work clothes, but only while in use.
DAMMIT TOOL: Any handy tool that you grab and throw across the garage
while yelling DAMMIT
at the top of your lungs. It is also, most often, the next tool that you
will need.
Old Apr 6th, 08, 11:33 AM
67CamaroRS/SS 67CamaroRS/SS is offline
Gold Member
Charlie
Default Re: Tools
I agree 100% with all of the following.
Charlie Knudsen 67 Camaro RS/SS 350 TKO 600, 4.10's, AFR 195 Street Heads, Comp 270H, Rhoads lifters, Crane Ignition, Pertronix dizzy, Performer RPM Q-Jet, Q-Jet, Hooker Comp headers, MagnaFlow 2 1/2", 144 decibles(Alpine CDA-7998 head unit, RF X7 and 750X amps, MB Quart speakers)
Old Apr 7th, 08, 08:02 PM
hokiez28 hokiez28 is offline
Tech Team
Ben
Default Re: Tools
Alan,
i love it , i hope you don't mind if i print and share it at work .
thank you
ben
Old Apr 8th, 08, 12:31 PM
amartinson amartinson is offline
Andy
Default Re: Tools
Couldn't be more true.
Old Apr 8th, 08, 07:44 PM
Gold Member
Alan
Default Re: Tools
I had to laugh when I first saw this because I've been there on some,2 ton hoist & the dammit tool !!!!
