| Team Camaro Tech Current Topic: Need help selecting front coil springs | ||
Can anyone please help me select new front coil springs? I need to get better weight transfer. It is a 67 Camaro and has serious traction problems. I need a perfectly prepped track or I just blow the tires off. Even with a good track, I still spin 20-30 feet. Best ET to date has been a 10.55 @ 128. Also, how should I have the shocks adjusted? I have found that the best so far has been all the way loose up front, all the way tight in the rear. Here's what I have now:
Front: Hotchkis 2" lowering springs QA1-R adjustable shocks new urethane bushings in upper & lower control arms disconnected sway bar, soon to be removed 8" steel ralleys, hope to replace with skinnies Rear: Hotchkis 2" lowering multi-leaf springs QA1-R adjustable shocks soon to be installed Cal-Tracs 275/60/15 MT ET SR 8" steel ralleys, hope to replace with lighter Weld rims The car: big block, aluminum heads battery relocated to trunk heater box removed glass hood that weighs almost as much as a steel one TH-400, 3200 stall, 3:55 car weighs 3650# w/driver I would appreciate any help. It was very frustrating last year to have so much power available, but not be able to put it to the ground. Don't get me wrong, the "have so much power available" part was still a ton of fun!! |
| Sponsored Links | ||
Advertisement | ||
car weight for front will help you get the rigght springs,i have my shocks adjust to middle setting.If it comes up to fast you unload 10-20 ft out.
But i'd wait to 40 coupe's comments.I could be wrong
Just because it don't look fast doesn't mean it isn't Just because it looks fast doesn't mean it is. www.eastcoasthotrod.com |
I wish I knew, but I have no way to weigh the front. I listed what was done to the car in the hopes that someone has a close set up and knows their front end weight.
| Sponsored Links | |
Advertisement | |
