Old Apr 22nd, 08, 07:34 PM
fatblock fatblock is offline
Default blower scoop
Dual 850 dp,s atop a weiand 8-71 with a 4" cowl hood.Enderle style,Hilborn?I am concerned with intake restriction and the small air filters that fit in these type scoops.Any suggestions for looks vs hp loss?
George
68 Camaro
8-71 blown 461 Rat
Old Apr 22nd, 08, 08:14 PM
1969ProStreetCamaro 1969ProStreetCamaro is online now
David
Default Re: blower scoop
George,
I can't answer your question in regards to the air filters in the blower scoop but a couple of guys here can. rat3j396 Jerry has a blown 427
prostreet69camaro
Mike has a blown 502
Either of them should be able to answer your question. BTW,do you have any pics of your ride? We sure would like to see it!!!!!
"All I need is a fast machine". Steve McQueen
My Machine: 1969 Pro Street Camaro
468 CID 648 Horsepower Turbo 400
33"x19.50" Mickey Thompsons
Check Out My Pro Street Camaro
648 Horsepower 468
Old Apr 22nd, 08, 08:48 PM
prostreet69camaro's Avatar
prostreet69camaro prostreet69camaro is online now
Mike
I dont run air cleaners in my scoop. I tried it a couple of times and it made the motor run richer and I did not want to start messing with the jets. It took me a while to get it dialed in.
Mike
69 Camaro Prostreet - purple w/ghost flames , 502 w/ 871 blower
http://s268.photobucket.com/albums/j...treet69camaro/
Old Apr 22nd, 08, 09:11 PM
David..I must say that is one fine pro street 69.
My 68 should be up and running in 30 days.I am close to finishing and getting some thoughts and suggestions from the Pro Street crowd.By all means..I will post some pics when I figure out how.I can boost referance carbs and correct rocker geometry..but my fat old fingers turn on and off several features with a digital camera.lol.Aside from the hp loss.what do you think about blower scoops.Some say the enderle style is plain wrong unless fuel injected(looks like ET from the movie).The Hilborn is classic,I like them both.As you can imagine..I did not opt for dual 850,s just to choke off the 8-71 with restrctive filters.Just to add,this pro street forumn is long overdue.Big engines and steam rollers never go out of style imho.
George
68 Camaro
8-71 blown 461 Rat
Old Apr 22nd, 08, 09:28 PM
I sometimes get into dusty conditions in my commute.Always seems to be some type of road construction going on with concrete saws billowing concrete dust.I can not see how this would benefit my rotor to case clearances.That shotgun scoop is a mean look for sure...but i will filter the air on the street.The rotors and case are not hard anodized...just a out of the box Weiand 8-71.
George
68 Camaro
8-71 blown 461 Rat
Old Apr 22nd, 08, 10:50 PM
rat3j396 rat3j396 is offline
Jerry
I've had this motor in another pro-street Camaro (1981) and a '69 Chevelle. It has a 671 Weiand and 2 Holley 750 DP. I use two 6 inch x 2 inch high ( i think) round filters. I've never had a problem. However, I've also had a 6000 RPM pill in the MSD at all times. I've used the "paper' filters, but K & N makes filters that size, I believe. That should improve air flow.
Jerry
67 RS coupe, Black
68 Pro street Torch Red, blown 427
Old Apr 23rd, 08, 03:39 AM
Pro-Street69Camaro468 Pro-Street69Camaro468 is offline
Gold Member
Dave C
I'm having the same problem just hight of hood clearence I can only get a 14x2 filter and my buddy says a 14x3 would be better and I'm only at 500hp.Another words I'm no help either.Sorry
Old Apr 23rd, 08, 08:05 AM
Jerry
If the filters can't handle the cfm, they will probably collapse from the vacuum. The screen type gasket between the blower casing and the carb mounting plate provides extra insurance from objects being sucked down into the motor. I have a friend who left the foam cover in a dragster scoop (fiberglass) once, and the vacuum created collapsed the scoop. And that was on a naturally aspirated motor.
...as for the Shotgun scoops...
ET?! I was thinking they looked more like "ALIEN"
I had the older style but opted for this style...just like anything on a custom car...it's about what YOU like, not so much what others think.
Good luck with your car George, can't wait to see it!
Jerry
67 RS coupe, Black
Old Apr 23rd, 08, 02:35 PM
Mike
George,
Speedway Motors sells the shotgun scoop. They sell them polished or unpolished / blemished. I would not buy the polished one because it still has blemishes and when you polish it you will not be happy. I bought the blemished one and had it chromed.
Mike
Old Apr 23rd, 08, 05:58 PM
David
Thanks for the compliment George. As for my preference on a blower scoop,the Hilborn looks better to me than that scoop that Mr. Gasket sells that "looks" like an Enderle injector hat. I just about puke when someone pulls up next to me in their "beater" and the first thing you notice about their car is that thing that they had to cut a hole in their hood just to put it on and the linkage to open the butterflies isn't even hooked up.Now if we're talking fuel injection,the "bug" or "bird catcher" is the only way to roll.About posting pictures,you are welcome to contact me via a PM(private message) and you either send them to me that way or I can give you my email address to send them to me.
648 Horsepower 468
Old Apr 23rd, 08, 07:13 PM
Thanks guys.First off,i would like to say how impressed i am with the qaulity and workmanship that shows in your builds..
FWIW..I am leaning towards the Hilborn style and thanks jerry,I will fill it with K@N,s and wartch for collapse.
Mike..is that a 6" cowl hood?Mine is a 4".Curious if my upper pulley will be exposed.
Thanks David for the offer to post pics.If my dumba$$ can not figure out how to post pics..I will hire the 3rd grader next door..or take you up on the offer..
Can i pick your brains?This may belong in performance or engine,but I am looking for a baseline start up with the Holleys.
I purchased 2 850 dp,s new out the box.They are fitted with #80 main jets front and rear and no numbers on the pv,s front and rear.My Holley referance book state they are 6.5,s.I will test them with a vac gauge to be certain.
I plan on blocking off the secondary pv and upping to #88,s.I plan on leaning out the primary to #78 and keeping the primary 6.5 pv.I blocked off the vac source in the main body for both pv chamber and port vacuum.
I drilled on an angle into the pv chamber and will use the ported vac nipple and source it under the blower.
The carbs have 4 corner idle mixture screws..will this set up ballpark me until I can get some running vac/boost #,s?The .030 over 460 will have around 7.5/1 static..cam will be dual pattern with mid .500 lift and 240ish @.050 with a 114 lsa.heads flow I350/E275cfm @.600" lift.I will test fire and break in n/a,then install the 8-71 12% underdriven and tune from there.Am i close with the carbs for baseline??
George
68 Camaro
8-71 blown 461 Rat
Old Apr 23rd, 08, 08:11 PM
Jerry
George,
I joined this forum a short time ago, and these guys are VERY skilled and knowledgeable, not to mention helpful!
Here are some pics with a 4" cowl hood with a 671. The members of the forum even gave me guidance on how to measure and cut it! As you will see, I opted to cut the hole a bit close, which causes me to remove the scoop before opening the hood. A body shop had cut the hood on my Chevelle like this a while back, and I just liked the look. I may end up trimming the rear of the opening a bit, but hopefully this will give you a general idea of what to expect. If you're racing, it may be a bit of a hassle.
You can get by with not cutting for the pulleys if you like. You can use smaller diameter pulleys and still maintain underdrive/overdrive ratios. There is a grid in the back of the Holley/Weiand catalog, or I believe it is available online on their website tech area. My blower uses the 1/2 pitch pulleys. I have a '34' on top, and the hood clears it. The 871 may be longer, which may make this info irrelevant, so i apologize if that is the case.
I wish I would have spoken with Mike earlier about the scoop. You can see how much better his looks chromed versus the polished one I have.
Jerry
Click image for larger version
Name:	camaro hole in hood 001.jpg
ID:	6349   Click image for larger version
Name:	camaro hole in hood 002.jpg
ID:	6350   Click image for larger version
Name:	camaro hole in hood 003.jpg
Jerry
67 RS coupe, Black
Old Apr 23rd, 08, 08:28 PM
David
George,
Since I don't have a big ol' blower on my car I can't help you with your tuning issue but I know either Jerry or Mike will know how to help you . Kinda wish now that I had put a blower on my car.
648 Horsepower 468
Old Apr 23rd, 08, 08:45 PM
Thank you for the pics Jerry.It helps me visualize.My 8-71 uses the 8mm belt and a 61 upper/54 lower for now..i was looking at Mikes side views of his pro street and it appears to be a 6 inch cowl..maybe a 4".Hopefully Mike chimes back in.I would like the upper pulley exposed on this little street deal only.A little bit of show.a little bit of go.Nothing fancy..just an honest 700 hp blown big block in a first gen..
George
68 Camaro
8-71 blown 461 Rat
Old Apr 23rd, 08, 08:55 PM
Jerry
David, your '69 is Badass just like it is!
Jerry
67 RS coupe, Black
