Crush sleeve - Team Camaro Tech
Old Apr 28th, 08, 09:18 AM
WV6TY7 WV6TY7 is offline
Bill
Default Crush sleeve
Guys... Rebuilding a GM 10 bolt 8.2 rear end. Please explain the difference in a crush sleeve and a spacer. I ordered a rebuild kit from Summit which included a crush sleeve like the original which is about 4 inches long. Unfortunately it got crushed a little too far during setup. So, I thought it would be easy to go to the local GM dealer and get another. All they had was a little spacer about a half inch thick. Their mechanic said some pinions let you use the spacer instead of a crush sleeve. I opted to order the one like I had from Summit but I am trying to figure out what he was talking about....
67 - Coupe - Bahama Blue, 427 SBC, TKO 600, Hotchkis TVS, Eaton Posi / 4.11
http://www.fquick.com/WV6TY7
Old Apr 28th, 08, 01:16 PM
12run 12run is offline
Default Re: Crush sleeve
They make a crush sleeve eliminator kit that uses a spacer and shims to set the bearing preload instead of the crush sleeve.
69 RS 355 Tremec 5-Speed 4.11's
Old Apr 28th, 08, 01:29 PM
zdld17 zdld17 is offline
Don
If you can't wait, some of these crush sleeves can be found at many parts stores in the HELP sections. O'Reilly is where I found mine , on a weekend. Seen the selections at Autozone and PartsAmerica.
Don
TC # 349
Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E
http://s102.photobucket.com/albums/m...t=115_1577.jpg
Old Apr 28th, 08, 01:34 PM
Bill
They had ones like this http://store.summitracing.com/partde...5&autoview=sku in parts stores which is what the dealer had. But mine had one like this http://store.summitracing.com/partde...5&autoview=sku . I am just struggling to understand how they are interchangeable....
Old Apr 28th, 08, 04:07 PM
Everett#2390's Avatar
<Jake 68's Rule
The short sleeve fits between a ledge on the pinion shaft and the front bearing as opposed to the longer sleeve fitting between the both front & rear bearing inner races.
Both serve the same purpose, but different routes of action.
Give a man a rescued dog for the health of his soul.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
