1969 Camaro Convert Auto to Manual - Team Camaro Tech
Thread Tools Display Modes
Old May 12th, 08, 05:30 PM
b.w.t.road b.w.t.road is offline
Tech Team
Road/Christian
Default 1969 Camaro Convert Auto to Manual
Budget is the key. Looking to spend $800-1000 total so Tremec is out. What components?. Trans, bell housing, clutch, shifter, pedals, z bar, crossmember, driveshaft. Anything else. Car is a 350/350 car currently.
1969 Camaro- My Fav.
2001 Silverado- Tow mule/DD
1986 Toyota- Off road truck
2005 Hummer H2 on 37's- wifes monster
All vehicles Black
Old May 12th, 08, 06:53 PM
KevinW's Avatar
KevinW KevinW is offline
Kevin
Default Re: 1969 Camaro Convert Auto to Manual
If you stick a muncie in, then you can re-used the crossmember and driveshaft. You will need a longer speedo cable. If you have a console, you will need a few parts there, boot, plate, etc.
Old May 12th, 08, 07:14 PM
hypersport750 hypersport750 is offline
Rob
It has been talked about recently.
http://www.camaros.net/forums/showthread.php?t=133532
Old May 13th, 08, 11:56 AM
DROPTOPtimes2 DROPTOPtimes2 is offline
Jim
check out my thread. it might be helpful.
http://www.camaros.net/forums/showthread.php?t=98172
1967 rs conv. hugger orange, 350 engine, former turbo 350 tranny-now SUPER T-10!!
http://img.photobucket.com/albums/v63/hubacek1/sig.jpg
1969 blue SS 'vert, 350 engine, 4 spd
http://img.photobucket.com/albums/v63/hubacek1/blue.jpg
Old May 13th, 08, 07:59 PM
JimM JimM is offline
Jim
Originally Posted by KevinW View Post
You will need a longer speedo cable..
If you find a trans that has a drivers side speedo (a non-camaro trans) your existing speedo cable will fit.
Make sure the trans is a coarse spline input shaft (10 spline)
I did a PG to muncie swap years ago for a grand, found the trans on ebay for around $400, new hurst shifter and install kit ate up $250, found a used bell on ebay cheap, used flywheel cheap, new pedals, linkage, and clutch.
Old May 13th, 08, 09:38 PM
TJS69 TJS69 is offline
Tom
I think you better double your budget to get that job done, now. As Jim said years ago.
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Transmission & Driveline      Current Topic: 1969 Camaro Convert Auto to Manual
Location
Location
First Name
Human Verification
