No turn signals - Team Camaro Tech
Camaro Tech General Tech Area
Old May 27th, 08, 05:30 AM
carpintimidator carpintimidator is offline
matt
Default No turn signals
Hello,
Please help I have a 68 Convertible the hazzard lights are working but i dont have any turn signals. Does this sound like the turn signal switch or the relay? If it is the relay where is it?
Thanks Matt
Old May 27th, 08, 06:15 AM
Everett#2390's Avatar
<Jake 68's Rule
Default Re: No turn signals
If you have flashers and stop lights, then the t/s flasher needs changing.
Give a man a rescued dog for the health of his soul.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
Old May 27th, 08, 06:41 AM
JimM JimM is offline
Jim
Worth noting that the flasher in the fuse box is ONLY for the hazards. There is a second flasher mounted in a clip screwed to the lower edge of the dash, just to the left of center, for the turn signals.
Also, a whole lot of problems like this in 67-68's especially can relate to bad grounds in various places... you might do a very careful "walk around" and check to see exactly what works and what doesn't... do this both with the headlight switch on and with it off.
Old May 27th, 08, 06:57 AM
matt
Thanks for the help but can you clerify what the t/s flasher is and where?
Old May 27th, 08, 07:41 AM
Unreal Unreal is offline
Gary
T/S is turn signal, and it's located where Jim said.
Old May 27th, 08, 09:09 AM
<Jake 68's Rule
As said, to the left (driver side) of the steering column sitting in a metal clip.
Old May 27th, 08, 09:51 AM
Jim
To the left of the raised center section of the dash, to the right of the line where the right side of the removeable cluster section is. (67-68 only, I have no idea where it is on a 69!)
It's pretty much directly below the ignition switch.
Old May 27th, 08, 11:57 AM
prostreet69camaro's Avatar
prostreet69camaro prostreet69camaro is offline
Mike
On a 69 it is above the radio under the dash. It is in a metal clip. What is funny about the flasher is I have owned my camaro 27 years and my blinkers were always slow blinking. Then I finally got tired of them, I started troubleshooting them and found out the relay was different than the one on the fuse block. When I found it and unplugged it, it broke in my hand. I replaced it and they work great now. Go figure!!!!!!!!!!!
Mike
69 Camaro Prostreet - purple w/ghost flames , 502 w/ 871 blower
http://s268.photobucket.com/home/pro...maro/allalbums
