Old May 28th, 08, 03:50 PM
Blade's Avatar
Blade Blade is offline
Matt
Default headers
Alright I am notice that I am gonna need new headers. I have only a 1 1/2 tubbing and that isnt gonna work with that motor. I was wondering that headers you guys are running and what would you suggest?
Just a little info about the motor, 431 bb around 650 hp roller motor nitrous.
thanks
Got to give the PEOPLE what they want!
Look....if you wanna be the best then you gotta take out the best!
1967 Prostreet Camaro
BB 431 650hp
400 Turbo Trans
Ford 9" 4:56 gears
http://www.cs3automotive.com/index.php
Old May 28th, 08, 04:19 PM
prostreet69camaro's Avatar
prostreet69camaro prostreet69camaro is offline
Mike
Default Re: headers
Matt,
I have the Hooker Super Comps # 2205. They are 2" pipe. They fit pretty nice with power steering. I believe you have a rack so it should not matter. Only thing I dont like about them is the driver side sits lower and I have smashed both sides because my car sits very low. I was running about a 26" tall front tire and changed to a 28" tall tire. That helped alot. If I was to buy a set again I would buy Lemmons but they are over twice as much money.
1969ProStreetCamaro ( david ) just ordered a set from Lemmons. He can tell you all about them.
Mike
69 Camaro Prostreet - purple w/ghost flames , 502 w/ 871 blower
http://s268.photobucket.com/albums/j...treet69camaro/
Old May 28th, 08, 04:38 PM
Blade's Avatar
Matt
Default Re: headers
Originally Posted by prostreet69camaro View Post
Matt,
Thanks, I think the 69 we have has the same ones because they sit really low. And the ground has smashed them up. I just went on to jegs and its seems that they all are 1 5/8s
BB 431 650hp
400 Turbo Trans
Ford 9" 4:56 gears
Old May 28th, 08, 06:10 PM
1969ProStreetCamaro 1969ProStreetCamaro is offline
David
Default Re: headers
Matt,
My Lemons Headers will be delivered this week. I ordered part # BBPT-600. They are an individual header flange design which allows for installation of the headers with the engine in the car. 2 tubes install from the top and 2 tubes install from the bottom on each side. They are designed to provide excellent ground clearance. According to Dan Lemons, they will be higher than the oil pan in the car. My header tubes are 2 1/4".
They are, of course,equal length tubes. They are designed to work with small block or big block frame mounts. All tubes are fabricated to fit between the frame rails and work with or without power steering.
Here are some pics from Dan's Website.........
Here is the link to the BBPT-600 headers if you want to check them out. They are expensive but the quality of work is impressive!!!!!!!!!
http://www.lemonsheaders.com/products/bbpt-600.htm
"All I need is a fast machine". Steve McQueen
My Machine: 1969 Pro Street Camaro
468 CID 648 Horsepower Turbo 400
33"x19.50" Mickey Thompsons
Check Out My Pro Street Camaro
648 Horsepower 468
Old May 28th, 08, 07:14 PM
Blade's Avatar
Matt
Default Re: headers
those things look great.
BB 431 650hp
400 Turbo Trans
Ford 9" 4:56 gears
Old May 28th, 08, 07:24 PM
David
Default Re: headers
They'll look even better when they are in the engine compartment of your '67.
648 Horsepower 468
Old May 28th, 08, 08:32 PM
camaroman7d camaroman7d is offline
Royce
Default Re: headers
I have a set of Lemons headers as well. They are GREAT pieces. Mine were one off custom headers for my car but, it was money well spent. I happen to live close enough (~3 hours) and took my car down to them. VERY good people to deal with. I don't leave my car with anyone and they are the only people to touch it other than me. If you have the extra coin they are worth it. They will fit and fit right.
Royce (NO XQSSS) Bradley
Pictures
Sound Clip
(brief sound clip, 3" exhaust through Borla Sportsman mufflers)
"If you are not part of the solution, then you are part of the problem" Me
Old May 29th, 08, 07:38 AM
Blade's Avatar
Matt
Default Re: headers
lol
BB 431 650hp
400 Turbo Trans
Ford 9" 4:56 gears
