How to find out my RPM band without knowing any cam specs? - Team Camaro Tech
Old Jun 16th, 08, 05:31 AM
tgifford5 tgifford5 is offline
Team Member
Ted
Default How to find out my RPM band without knowing any cam specs?
I am trying to decide on a tranny swap. And it was stated to me that it is important to know what the cars RPM band is. To properly engineer a driveline. I do not know any of the cam specs. since it was installed prior to my ownership. How do I find out what my rpm band is? By getting it dynoed? Any other ways? Any other info you need to know to help out? Thanks.
Old Jun 16th, 08, 09:48 AM
speedshifter speedshifter is offline
Kevin
Default Re: How to find out my RPM band without knowing any cam specs?
A dyno sheet will tell you where your powerband is, but so will your backside. Where does the car pull the hardest? Where is the point where you can feel it stop pulling really hard? Can you take it to the drags? If so, experiment with different shift points and see what happens to your ET.
All of this will give you ballpark figures to work with, not as good as knowing what parts you have.
Autosmiths, LLC
'69 X44, stock 350 (for now), TH350, 3.70:1 gear 8.5" 10 bolt, Auburn Posi.
Old Jun 16th, 08, 11:18 AM
dnult dnult is offline
If you have a manual transmission it's easy to find out. Put the tranny in a gear that makes the engine lug at about 1200 RPM or so and hold the accellerator steady. Note where the RPMs (and MPHs) begin to pickup. Finding the fall-off point is a bit more difficult.
Dave
68 Coupe, 350 w/ Edelbrock Performer RPM heads, cam, intake, 700R4, Dave's small body HEI
Old Jun 16th, 08, 03:33 PM
pdq67 pdq67 is offline
Banned
Smile Re: How to find out my RPM band without knowing any cam specs?
I hate to say it, but pull the cam so you will really know what you have!
Then go from there.
pdq67
Old Jun 16th, 08, 05:09 PM
LCAC_Man LCAC_Man is offline
Len Barron
Chasis Dyno, pay for a tune as well, worth every penny.
Len
67 SS-350 Convert.
406/200r4/12b 3.73's Truetrac
Len's PT Garage
