Muncie Shift Patterns - Team Camaro Tech
Thread Tools Display Modes
Old Jun 23rd, 08, 03:28 PM
Microgiant Microgiant is offline
Timothy
Default Muncie Shift Patterns
I did a search for this but I couldnt find anything. Maybe I am using the wrong terms? But Im curious to know what shift patterns were available for Muncies (and any other info you care to add)? Currently the one I has feels like its 1 down 2 up...
My 69 RS/SS 396 Project - www.easymoney69.com
"I may be dumb but I aint stupid"
Old Jun 23rd, 08, 04:06 PM
cam67 cam67 is offline
Jim
Default Re: Muncie Shift Patterns
Typical US four speed pattern with reverse to the left and up. Move the shifter to the right and 1st is up, 2nd straight down, up and past the neutral gate to 3rd and down to 4th.
Old Jun 23rd, 08, 05:02 PM
Codi's Avatar
Codi Codi is offline
Jim
H H H All Muncie 4 speeds are H
Daddy's Hot Rod.
http://www.camaros.net/showroom/show...e=365&way=desc
Old Jun 23rd, 08, 05:30 PM
Rodder's Avatar
Rodder Rodder is offline
Jon
My 67 had a Saginaw 4-speed with levers from a 3 speed. The only way to make that fit is to flip the 3-4 lever upside down, which made the shift pattern look like this:
R 1 4
_ 2 3
Anyway, what do you mean by "1 down, 2 up"? Up/down is a motorcycle thing and would be 1 N 2 3...
1968 Camaro Convertible - LS1, T56, Hooker longtubes, Autokraft pan & mounts, GM LS7 clutch, Borla ProXS, Moser/Strange/Wilwood 9", Covans dash, UltraLite IIs, Procar Elites, Vintage Air GEN-IV, AGR 12:1 steering, Addco swaybars, Hydratech hydroboost
Old Jun 23rd, 08, 05:38 PM
Andrew69's Avatar
Andrew69 Andrew69 is offline
Andrew
If your 1 & 2 and 3 & 4 are flip flopped in the "H" pattern your levers attached to the tranny may be installed incorrectly. When in neutral they should point up, not down. Been there, done that.
Skunk Works
302DZ, M22W Muncie, GV overdrive,12-Bolt Rear 3.73
Some photos: http://www.camaros.net/showroom/show...0&ppuser=11587
Member # 159
Old Jun 24th, 08, 12:15 AM
Timothy
Ooops I MEANT TO DO IT THAT WAY. YEAH. Im planning on a european road trip and everything is backwards.
Old Jun 27th, 08, 09:18 AM
deerhunter deerhunter is offline
That could have been bad if you would have speed-shifted at maximum RPM!
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Transmission & Driveline      Current Topic: Muncie Shift Patterns
Location
Location
First Name
Human Verification
