| Team Camaro Tech Current Topic: Tunnel ram advantage? | ||
In a motor built for track only, and 3500-7500, when do you begin to see gains with a tunnel ram setup over a single carb setup? And how substantial are those gains?
The reason I ask is, I wonder if my motor is being choked by the 750 dominator and victor jr intake, especially considering the manifold has a 4150 type flange, and thus requires an adapter to mount the 4500 flange dominator. If I were to rework the setup, I'd either sell the dominator and adapter and get a barry grant carb (something in the demon series) OR sell the the intake and adapter and pick up either a Brodix intake with dominator flange that would match my heads, OR sell the whole shebang and go to a tunnel ram and dual 500 or 660 setup. But I don't know which setup will net me the most benefit. Engine: 407 Ci, 40 over 400 splayed mains, poured with rock block (half), steel crank, Eagle rods, Wiseco pistons, molly rings, solid roller Reed cam Duration at .050 is 262/267 ADV Duration: IN 296 degrees, exhaust: 302 degrees Lobe Lift: IN .412" EX .417" Vavle Lift: IN .618" EX .625" @1.5 RR Valve Setting: IN .020" EX .022, zero decked block, Brodix Track I heads, 2.01 intake, 1.65 exhaust, intake runners 215 cc, triple valve springs, compression ratio 13.2 to 1, receiver grooved heads, block wire head gaskets, Victor Series intake, 750 Dominator carb., Hooker 2 inch longtube headers, 3 inch X pipe with 1 chamber Flowmasters. Transmission: Turbo 350 trans. with reverse valve body, 4400 stall converter. Rearend: 12 bolt GM differential, 456 ring and pinion with mini spool. Ignition System: MSD ignition, 7AL-2 with two-step, with rev. limiter pills. General Information: Channel for 4 link suspension. Car Weight: 3090 lbs. (without the driver) Brake line lock, trans. brake, B & M rachet shifter, Southside traction bars, 8 point cage. Car will run high 6's in the 8th on motor only as it sits. I am sure some of you have an opinion on this... let's hear it. A desktop dyno sumlation possibly? |
| Sponsored Links | ||
Advertisement | ||
Hey neigbor!
I think there is a reason you see very few if any SBCs running tunnel rams at the track. While your combo sounds pretty hot, I doubt that a single carb with the right intake would be choking it and would be much easier to setup correctly than two carbs on a tunnel ram. IMO 750 Dominators are not a very popular carb . . . have heard there are some "challenges" with them, but cannot remember exactly what. I will say though that putting a 4500 carb on a 4150 manifold using an adapter will cost some power - not the best way to go. I personally think that a properly prepped Vic Jr manifold with a good 4150 style 950 HP carb would be plenty for your ride.
E85 racer and E85 carb builder www.horsepowerinnovations.com 68 Camaro, E85 powered 427" small block. 9.96 @ 133 MPH, 1.319 sixty foot on motor. 5.92 eighth @ 116 with a 1.42 sixty breaking beams with back tire on the bottle |
69 Camaro, hugger orange with black stripes. |
That victor jr is costing you a pile of power and torque. I would look into larger intake with a dominator style flange like super victor, brodix hvh, or dart wilson. You have to remember that the victor jr has been around for a long time. It is old technology. Also tunnel rams make a lot of power when prepped properly. It just takes a little "tinkering".
Just my thoughts. |
Does anyone have a desktop dyno where they can put my combo in and simulate different types of induction? Tunnel Ram, super victor, brodix, etc?
If you don't mind me butting in, I asked this question about my big block, the other month on DDR site and it appears you'll get a lot of conflict. Several people informed me to us a single plane intake, such as a holley strip or a team G and a single carb, while others told me that if you plan on draging the car, a tunnel ram, when setup properly will give you a good amount of extra HP. When I ran some numbers on the program I use, a tunnel ram, can drop me into the low tens, just by adding one on.
But the question is, do I want to spend a lot of extra money buying one, when all I would have to do is spend 1/2 that amount and buy a new intake and a larger carb. So I guess the real answer is really up to you? Do you want to spend, at least 800.00 for a tunnel ram set up or more, or do you want to spend less and have a lot less headaches with the setup? A friend told me, he bought a ram, bought two new holleys, out of the box, bolted them on and it made a big difference after getting the setup just right. Good luck with the end results. They sure do look neat though..... Bruce [img]graemlins/thumbsup.gif[/img] www.hobbystage.net/camaro/rolandracing |
I agree the victor jr. is not helping. They were made for a heavier car and a milder motor. Your convertor will hurt you if you do go to a tunnel ram (if it's really a race only deal think about stepping up with a different convertor, it will help) The car is light enough but most tunnel rams are a little light on power at 4400 rpm. Try a good single plane and think about a different carb.
Well, I picked up a used Weiand tunnel ram off ebay for about $100. Whether or not I'll use it, I don't know. I also found a brodix intake hv1002 that sounds pretty good and should match the heads I have pretty well as well as having a 4000-8000 rpm range according to the manufacturer. It has a dominator flange so I could keep my carb without the adapter as well. I dunno if the 750 dom is enough carb, but unless I can sell it and the vic jr, funds don't permit another $600-$900 expenditure on a carb right now..
Also, I was reading that the track1 port size is 221, not 215 as I was originally told.
I'd like to sell the rear end and go to a 9 inch so I can play with gear ratios a bit easier too. The car was setup originally for an 8th mile track, but all we have around is here 1/4. I'm a little concerned about running out of gear, especially if I add a fogger down the road... So would a 4.10 gear change your converter recommendations?
The hv 1002 would work good for your application. Also have you ever thought about letting a reputable carb shop work on that 750 dominator. Amazing what they can do. Might also save a few coins.
#11
#12
I may have missed something, but have you run the carb as is right now? How did it do?
If you haven't, I'd wait and see how it runs first.
Matt Jones Lead Mechanical Engineer Art Morrison Ent. Inc. |
#13
I have used them with 5500 convertors and found in all cases the car was faster with a single 4bbl. Mine were always the higher rpm models but even the ones designed for lower rpm (unless you can find one made for a boat) have an awful lot of volume to do much even at 4400 rpm. We ran them with 4spds even in a 4000# car it picked up almost 5mph over a single 4bbl.
#14
I think he left the word "than" out..
pdq67 |
| Sponsored Links | |
Advertisement | |
