Need a picture of a 67 Camaro Fuse Panel - Team Camaro Tech
Old Jun 29th, 08, 08:15 AM
HBBob HBBob is offline
Bob
Default Need a picture of a 67 Camaro Fuse Panel
Does anyone have any pictures of a 67 Camaro fuse panel that show how it’s mounted to the firewall? I took mine off about 6 months ago and now I can’t figure out how it goes back on, didn’t seem too difficult at the time. I’m starting to think that it’s not the original fuse panel. Thanks
HB Bob
1967 Coupe 350 5 spd
Old Jun 29th, 08, 01:54 PM
Johns 67 Johns 67 is offline
Default Re: Need a picture of a 67 Camaro Fuse Panel
This is what I have. Hope it helps!
Old Jun 29th, 08, 10:15 PM
IDS_Bill IDS_Bill is offline
Team Member
Bill
I'Hope these help...
67 Yenko Tribute - 427/4SPD/Bolero Red
2010 2SS/RS Camaro - Victory Red with White Rally Stripes
http://www.67yenko.com
http://www.dive-ids.com
http://www.azdivetraining.com
Old Jun 30th, 08, 07:55 AM
dnult dnult is offline
Excellent images. Jim M. shall we add these to the what it is where it is sticky?
Dave
68 Coupe, 350 w/ Edelbrock Performer RPM heads, cam, intake, 700R4, Dave's small body HEI
Old Jun 30th, 08, 12:53 PM
Bob
Perfect, thanks!
HB Bob
Old Jan 24th, 12, 07:20 PM
stevepaa stevepaa is offline
Does anyone have a schematic showing the wires to each side of each fuse?
Old Jan 25th, 12, 05:00 AM
Camaro67_rcl's Avatar
Camaro67_rcl Camaro67_rcl is offline
Rick
http://www.rclabbe.com/rswiring/rswiring.pdf
Rick
67 RS/SS 355, Autogear M21 (w/Overdrive), 8.5w/3.42
http://www.rclabbe.com/jsp355/
Old Jan 25th, 12, 07:32 PM
Thanks, I have that schematic, but for the 1967 on page 14, there are three fuses which have no wires connected to them on one side. Anyone know which wires go there?
Old Jan 26th, 12, 01:48 PM
islanddean's Avatar
islanddean islanddean is offline
Team Member
Dean
Have a question about the "IGN.Fused" spot. I'm trying to hook an electric choke to this terminal on my 1967. Does the "fused" mean the wire running between the choke and terminal should have an in-line fuse?
1967 Camaro Convertible with a 327, TH350transmission, Edelbrock 1406 600cfm carb, Edelbrock 1721 fuel pump & 2701 intake.
"The true measure of a man is not where he stands in time of comfort and convenience but where he stands in time of challenge and controversy."
MLK
Old Jan 26th, 12, 03:40 PM
I think if you wiggle that spade connector you will see it is connected to the fuse in the adjacent slot.
My problem is I have no power to that fuse and I want to know which wire feeds it.
Old Jan 26th, 12, 03:47 PM
Depthrecordings Depthrecordings is offline
Eric
I would just run it to the hot wire on your alternator. Save yourself the trouble.
Eric.B
Denver, CO
1967 Camaro
My Project Progress
Old Jan 26th, 12, 04:06 PM
69-Pace's Avatar
69-Pace 69-Pace is offline
I think you already figured this out but it is as stated, the fuse beside the spade controls that spade. Most factory add on harnesses had a y connector that attached to the spade so the accessory would be powered and then the other y was a second male so another device could be connected in the future - as long as combined the two would overload the fuse.
1969 Z11 Pace Car - L48 350cid/300hp - 4 Speed Muncie 12 bolt rear
http://69pace.blogspot.com/
Old Jan 29th, 12, 10:56 AM
Here is a pic of the back of original 67 fuse block. I think I may need to get a new one as continutity is lost between some joints. The wiring from the front view left is 12R from battery feeds the two fuses on the left. The third fuse up is fed from 12P from ignition. The fourth up is fed by Green from light switch. The fifth, sixth and seventh up are fed by 12 BRN from from ignition switch.
On the right, the bottom fuse feeds and orange wire to light switch. The second fuse up splits into 2 orange wires: 1 to flasher and 1 to lighter. The third fuse up feeds a 20P to instrument cluster. The fourth fuse up feeds a grey wire to instrument lights. The fifth fuse up feeds a yellow wire to radio. The sixth fuse up feeds a brown wire to heater. The seventh fuse up feeds a yellow wire to wiper motor.
Well, I am disassembling the fuse parts, sandpapering the contacts, adding some solder to some of the joints, and it should work. Getting the connectors with added spade on them out of the box is difficult.
Click image for larger version
