what intakes fit on 2nd gen under stock hood - Team Camaro Tech
Old Jul 3rd, 08, 07:32 AM
olympic olympic is offline
Default what intakes fit on 2nd gen under stock hood
I've got a '73 camaro with a small block in it. Right now I'm running an edelbrock torker II low rise intake with an edelbrock 600 on it, and a 3 inch drop air cleaner.
I have under hood insulation on the car right now and it's a press fit....you can see the smashed outline of the air cleaner in the insulation.
I'm looking to pull out the hood insulation in hopes of giving me just a tad more clearance.
I'd like to know what others are running for aftermarket intake/carb/air cleaner combinations that fit under the flat (no cowl) stock hood of their 2nd gen camaros.
From what I see at edelbrock, it appears I should be able to get a performer RPM under that hood, but I just don't see how it will fit. Perhaps some air cleaners drop more than others...or perhaps even carb heights are a bit different.
Thanks in advance for any info.
John
'73 Camaro
Old Jul 3rd, 08, 10:49 AM
JediJawa JediJawa is offline
Adam
Default Re: what intakes fit on 2nd gen under stock hood
I ran the Edelbrock Performer RPM under the flat hood of my 71 RS without any clearance issues. I can not recall the exact breather I used but it did not drop down around the carb too far if I recall correctly.
My Current Baby:
1967 Camaro RS orig. 327 w/powerglide
deluxe bench front seat Int. w/ power windows,
factory A/C, factory four piston disc brakes,
454 Big Block currently w/TH400
Project in progress
Old Jul 3rd, 08, 11:02 AM
Thanks JediJawa for the info. Do you recall what kind of carb you were running? Apparently there are some minor carb height differences. I'm just pressed already with my low rise torker II, edelbrock carb and drop cleaner. glad to hear you were able to get a performer rpm stuffed under there. Did you have any under hood insulation?
John
'73 Camaro
Old Jul 3rd, 08, 11:26 AM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
Scott
Me too, w/holley 650. Some drop to the AC base, and a 3" AC
Scott from NJ. Stay thirsty, my friends
Vent Windows Forever! ... My junk ... NastyZ28 ... NJ Camaros & Firebirds
Feather-light suspension, Konis just couldn't hold
I'm so glad I took a look inside your showroom doors
Old Jul 3rd, 08, 12:34 PM
Adam
I did not have any hood insulation so not sure how close that was. I do remember checking clearance with some putty and had decent enough clearance that torque twist did not cause interference. I was using a Holley 4150 body @ 650 CFM. If I had to venture a guess of the past I'd say it was a 3" breather element with a recessed retainer nut.
Hope the vague recollections are useful in some way!
My Current Baby:
Project in progress
Old Jul 3rd, 08, 04:42 PM
pdq67 pdq67 is offline
Banned
Have you asked over at MadMike's great SGCOG site, NastyZ28??
Those guys can tell you CORRECTLY in a New York minute, imho..
Not trying to run you off tho..
pdq67
Old Jul 3rd, 08, 04:49 PM
ace's68 ace's68 is offline
AJ
If your looking for another single plane I have a Weiand Team-G and it is freaking sweet.
It's about as tall as my old edel performer but a single plane, it may fit your stock hood???
I have seen people just run flame retarders with no air cleaners for a quick fix, wouldn't recomend it.
I wouldn't pull the hood insulation I would bet your hood paint would get faded much more quickly.
The only Mustang I'd ever own is a Fender.
Old Jul 3rd, 08, 07:10 PM
davidpozzi davidpozzi is offline
David Pozzi
We have a performer RPM with Demon carb on our 73 Camaro. Clearance is good, our insulation pad is cut out around the air cleaner.
David
Check my web page for First Gen Camaro suspension info: http://www.pozziracing.com
67 RS 327 original owner. 1965 Lola T-70
Old Jul 3rd, 08, 08:54 PM
PDW HOTRODS PDW HOTRODS is offline
Patrick
It could be the carb. I had a Edelbrock 750, and a regular drop base air cleaner would not fit without a spacer. The air cleaner hit the fuel line inlet and the accelorator pump.
With a 1 inch spacer it cleared, but crowed the hood.
