Edelbrock 1406 WOT bog/stumble--how I fixed mine... - Team Camaro Tech
Camaro Tech General Tech Area
Thread Tools Display Modes
Old Jul 5th, 08, 02:15 PM
Brentmc's Avatar
Brentmc Brentmc is offline
Default Edelbrock 1406 WOT bog/stumble--how I fixed mine...
I've been having a bog from idle on WOT with my Edlebrock 600CFM 1406 carb every since I installed an Air Gap intake. I tried changing jets, spring, rods, timing, moving the accelerator pump arm, etc. NOTHING worked.
I finally found something that works--an Edelbrock #1468 accelerator pump ($12.95)--I bought it at Auto Zone and the bog is gone.
Edelbrock lists it as a "special accelerator pump" with a marine spring and marine-quality seal. This pump gives the carb the gas it wants when I floor it at idle.
Here are the specs
* Performer Series; Accelerator Pump Assembly; Incl. Pump/Spring/Cup; For PN[1412/1413/1812/1813] Carburetors;
* For PN[1409/1410]
* Includes Cup Assembly
* Marine Spring
* Marine-Quality Seal
* Special Accelerator Pump
http://www.streetsideauto.com/produc...artnumber=1468
I hope this helps.
Old Jul 5th, 08, 02:23 PM
68Holdon 68Holdon is offline
Robert
Default Re: Edelbrock 1406 WOT bog/stumble--how I fixed mine...
I cant wait to try it!!!! I have been dealing with the same issue for a year.
There are no problems only solutions
68 Camaro, RS/SS, ZZ502, Retrotek Fuel Injection, 4 Speed.
2010 RS/2SS Black, 6 speed trans
Old Jul 5th, 08, 03:54 PM
ace's68 ace's68 is offline
AJ
I'm about to throw my 1407 on the side of the road for it's next victim.
Same prob you were having.
The only Mustang I'd ever own is a Fender.
'68 333" Camaro
'14 5.0 Mustang
Old Jul 5th, 08, 05:50 PM
Brentmc's Avatar
well, I'll take that roadkill 1407 off of your hands....
Brent
Old Jul 5th, 08, 07:50 PM
hereitis67 hereitis67 is offline
bill
ill take any edelbrock carbs that are bogging and fix them without a rejetting.if on 2 barrels and is fine but boging while into 4 barrels. you dont need rejetting just air flow adjustment
Old Jul 5th, 08, 07:58 PM
Brentmc's Avatar
Mine was bogging when I floored it from idle. It would just die if I didn't let up on the gas.
Old Jul 23rd, 10, 01:41 AM
legaleagle legaleagle is offline
John
That's what you get after using the special accelerator pump ?
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Camaro Tech      Current Topic: Edelbrock 1406 WOT bog/stumble--how I fixed mine...
Location
Location
First Name
Human Verification
