GM Door sticker and tire pressure decal...help - Team Camaro Tech
Camaro Tech General Tech Area
Thread Tools Display Modes
Old Jul 26th, 08, 05:54 PM
ChuckD ChuckD is offline
Smile GM Door sticker and tire pressure decal...help
On my 69 Z, I have inherited the GM blue door sticker and the DX tire pressure decal, all on the drivers door jamb. After some lookin' here, seems this is incorrect.
1. GM sticker should come off?
2. Tire sticker should come off?
3. Tire sticker goes where?
Thanks all.....
69 Z-28,all original(darn near!), Date correct DZ-spec motor, -186 heads, 30-30 Crane, 1178 crank, and 11:1 hyper-eutectic pistons, stainless valves, original manifolds and carb, with smog. #'s trans and rear. Bling-free.
Old Jul 26th, 08, 07:25 PM
Gary L's Avatar
Gary L Gary L is offline
"Tri-Tip"
Default Re: GM Door sticker and tire pressure decal...help
No GM sticker until September build I believe. Could be later. Put the DX decal on the driver door edge .
"Government is not reason; it is not eloquent; it is force. Like fire, it is a dangerous servant and a fearful master." ..... George Washington
Gary,TC Member with a Lemans Blue/Ivory 02D X33, DZ, M20, MS, flat hood. Only the BU code rear end is original.
Old Jul 26th, 08, 09:08 PM
Thumbs up Re: GM Door sticker and tire pressure decal...help
Ok, Thanks Gary!
Old Jul 27th, 08, 10:11 AM
William William is offline
Whoa.
No 68 or 69 Camaro had the square GM door decal used in 1967.
All 69s had the tp label on the drivers door. Z/28s and COPO 9737 cars used the decal coded DX.
Cars built for the '70 model year were required to have a VIN certification label stating month and year of production. 1969 Camaros built begining 08A had the label. The door shell stamping was changed to include two stamped beads; the label is placed between them.
William
CRG www.camaros.org
Old Jul 27th, 08, 02:01 PM
Thanks again!
Old Jul 27th, 08, 05:10 PM
Gary L's Avatar
"Tri-Tip"
I wonder if the model year was dictated by the DOT? If so then maybe that is how '69 body style cars were licensed as '70 cars. Thus '70 1/2 cars for the 2nd gen body.
Old Jul 27th, 08, 06:05 PM
No 1969 Camaro was ever titled as a 1970 model.
There is no '70-1/2' Camaro; it was a 1970 model delayed due to tooling issues.
William
CRG www.camaros.org
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Camaro Tech      Current Topic: GM Door sticker and tire pressure decal...help
Location
Location
First Name
Human Verification
