Inside door emblems - Team Camaro Tech
Thread Tools Display Modes
Old Jul 30th, 08, 07:24 AM
quickboat quickboat is offline
jim
Exclamation Inside door emblems
Anyone know how to locate the inside door emblems on a 67 w deluxe interior. I dont have a Fisher body manual just the assy.
67 RS Deluxe Int. A/C car
TKO-600
400 4 bolt block .03 over
Ported 215 Pro1 Platinums
Forged/balanced 400 crank, pistons, 6" rods
286HR cam w/1.6 rckrs LS1 beehives
Forgelines, 18"f 19"r, 4 link w/ minitub
IROC s/gear, 4 wheel discs
Old Jul 30th, 08, 04:21 PM
jim
Talking Re: Inside door emblems
Nobody??
TKO-600
Old Jul 31st, 08, 05:11 AM
jim
Default Re: Inside door emblems
Nobody???
TKO-600
Old Jul 31st, 08, 05:29 AM
Eric Kammerer Eric Kammerer is offline
The info you need isn't in the FBM anyway. You're going to have to look at pics, or someon can give you measurements. It has been 20 years since I had my parchment deluxe 67, so I don't have anything to help. here's one pic, and I will search for something better.
http://www.universalautosalesandclas...erior3.jpg.JPG
Eric
69 'vert project big block/TKO 600 RR
68 'vert driver RS clone -- gone!
Old Jul 31st, 08, 05:36 AM
I couldn't find anything here, other than a few threads asking the same question with no response.
Eric
Old Jul 31st, 08, 11:47 AM
tejasrs/ss's Avatar
tejasrs/ss tejasrs/ss is offline
Armando
here's a question along these lines..is it possible to have deluxe door panels for a 67 WITHOUT the emblems?? I picked up a pair of door panels from e-bay last year but they DON'T have the emblems and there are no indications that an emblem was ever there. Maybe they are firebird door panels??
Armando
1967 Chevy Camaro RS/SS
2012 Ford F150 Supercrew FX4
2007 Ford Mustang GT/CS (sold)
2002 F150 Harley Davidson (sold)
Old Jul 31st, 08, 07:12 PM
jim
Mine aren't ressesed for them or anything but I was going to put them on to break up the monotone door panel. You might be right about these plain panels. Thanks Eric for the pic it will help greatly.
TKO-600
Old Aug 1st, 08, 05:50 AM
Never seen an original pair without the emblems; maybe you bought a pair of repros.
Eric
Old Aug 1st, 08, 06:31 AM
prostreet69camaro's Avatar
prostreet69camaro prostreet69camaro is offline
Mike
I agree with Eric. They are probaly repo.
Mike
69 Camaro Prostreet - purple w/ghost flames , 502 w/ 871 blower
http://s268.photobucket.com/home/pro...maro/allalbums
Old Aug 1st, 08, 03:59 PM
tejasrs/ss's Avatar
Armando
hmm..never thought of that. How can I tell the difference?
Armando
  #11
Old Aug 1st, 08, 04:54 PM
If they are in good condition, and they don't have an emblem, I say it is 99.9% that they are repro. I don't know about the original black ones, but the parchment deluxe panels in my high school 67 cracked in the armrest portion very early in its life, and it just got worse and worse. Materials today (as far as vinyl upholstery goes) are much better.
Eric
  #12
Old Aug 1st, 08, 05:00 PM
jim
Does anyone have repos then added emblems?? Hows it look?
TKO-600
  #13
Old Aug 2nd, 08, 06:42 AM
Dale8346 Dale8346 is offline
Dale
Installing Deluxe Door Emblems on 67 Camaro- by Dale
The only reason they are “recessed” is because they were put on so tight from the factory, that they were “squeezed” onto the vinyl and foam behind them. I don’t know if you could have ever bought an original door panel without the emblem. My guess is probably not, but I do not know. I would love to see a GOOD picture of the back of your panel.
Here are the measures to install it, they are for the Drivers Side Door Panel:
ALL the measures below are to the OUTER most Edge (tip) of the emblem. They are also from the middle of the nearest groove (line) in the vinyl. I used a Stanley 12ft PowerLock metal tape measure. Also note that if you are installing the emblem while the door panel is off the car, the emblem is not “straight” in appearance.
ALL measures below are from an ORIGINAL 67 Camaro Deluxe door panel in Good Condition.
Measurements of Emblem from the face of the Door Panel:
From the top of Emblem (middle of top) to groove above: 1 1/8”
Most Outer left Edge (again middle of this edge) to groove to left: 1”
Very Top Most Left Side of Vertical Line (corner) to line off to left: 2 ¼”
Very Bottom Most Left Corner of Vertical line to the line off to left: 2 5/32”
I kept the tape measure straight with the side edge of the tape against the vinyl feeling and keeping the hook of the tape measure in the middle of the groove.
Measurement of the posts from the back of panel:
Top post is 3” from the top of the panel , 19 7/16 from rear edge of panel
Most rear post is 3 ¾ from top, 18 5/32” from rear edge of panel
Most front post is 4 1/32 from the top, 20 21/32 from rear edge of panel
Again, remember that it will not look straight on the panel.
All my measures listed above and below are exact.
Measure below are the overall size of an entire Original 67 panel:
Be careful of using these measures above on a new repo panel. I would not want to guaranty that the overall width and height of the panels are the same.
But, lining this emblem up with these grooves in the vinyl is probably going to give you your best look. This will be true even though the overall panel may not be the same for the repo's.
Height taken on entire panel at the emblem center (vertical) posts - 18 ½”
Width taken from CENTER (height) of panel – 41 ¼ (maybe a smidge more).
  #14
Old Aug 2nd, 08, 06:54 AM
jim
Dale you are why this forum works...You da man!
I'll take pics when I take the panel off. Should be this week.
TKO-600
  #15
Old Aug 4th, 08, 03:54 PM
tejasrs/ss's Avatar
Armando
I'll have to run out to my storage shed this weekend and take a picture of the door panels. The last time I looked at them I noticed they had a cardboard backing and they "look" kinda old, maybe they're a pair of OLDER repro's??
Armando
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Interiors      Current Topic: Inside door emblems
Location
Location
First Name
Human Verification
