Heater box - Team Camaro Tech
Camaro Tech General Tech Area
Old Aug 5th, 08, 06:55 PM
softail02 softail02 is offline
Keith
Default Heater box
Hi guys,
Looks like my heater core is shot and I was wondering if I could swap it out with a big block heater box and core or are there other part for the duct that needs to be switched. I run fab valve covers and there is like NO room as it is for the hoses.
Thank you
70 RS Pro-Street
69 RS/SS wifes car
07 Tahoe LTZ
02 2500 crew LT Duramax
04 Fatboy
Old Aug 5th, 08, 07:37 PM
68IslTeal's Avatar
68IslTeal 68IslTeal is offline
Jeff
Default Re: Heater box
you can buy a bb core and firewall cover to convert from sb heater layout.
http://WWW.FQuick.Com/2Bad4Ya
Old Aug 6th, 08, 05:11 AM
Keith
Do I actually need to take the cover off to replace the core or is that done from the inside ? I have a feeling that when I installed the hoses i had to bend the tubing a little cause it was hitting the valve cover thats what might be cause in the leak
70 RS Pro-Street
69 RS/SS wifes car
07 Tahoe LTZ
04 Fatboy
Old Aug 6th, 08, 06:49 AM
BigBlock1969RS's Avatar
BigBlock1969RS BigBlock1969RS is offline
Ed
The Big Block Cover / Core moves the inlets out towards the fender where the small block is closer to the engine.
You would need to pull both the cover and the core to swap them out.
It is easiest to replace the core by taking the heater box out from inside (under the dash). But if you are changing out from a SB to a BB the cover on the firewall would need to be changed as well.
Hope this helps. There is a number of threads on the install/removal of heater boxes, just do a search.
Old Aug 7th, 08, 06:23 PM
Codi's Avatar
Codi Codi is offline
Jim
You can pull the heater box and convert it to a BB core with no problem. One retention clip needs a slight modification. The blower box needs to be modified for the BB core tubes. While it can be done with the cover in the car, it is much easier with it out. A 3/4 inch hole saw is needed as well as a cover for the new holes (many catalogs call it an adapter). A seal kit will also be needed. it probably needs seals anyway.
Daddy's Hot Rod.
http://www.camaros.net/showroom/show...e=365&way=desc
Old Aug 7th, 08, 11:05 PM
67Camaro972 67Camaro972 is offline
Tech Team
Jay Livingston
I swaped mine over from a sb heat core to a bb heater core by only removing the inside box. Left the outside box on and drilled the new holes from inside the car, after some very careful measurements, of course. Came out nice, used closed cell black foam over the old holes from the inside. Actually made a adapter/cover that cost me less than a quarter (scrap/left over 1/8 stainless steel plate) and a couple stainless self tapping screws. More of that black closed cell foam again. Hope that helps/.
