Old Dec 31st, 99, 07:08 AM
67FREAK 67FREAK is offline
Team Member
David
Post
DOES ANYONE HAVE ANY SUGGESTIONS OR COMMENTS ABOUT USING SYNTHETIC GEAR OIL IN A B/W SUPER T-10 4SPEED? I PULLED MINE OUT BECAUSE OF HARD 2ND GEAR SHIFTS, BUT THE SYNCHRO'S AND GEARS ALL LOOK GOOD. IT SHIFTS OK BELOW ABOUT 5800 RPM, BUT I SHIFT AROUND 6800, NO GRINDING, JUST HARD TO GET IN. I THOUGHT MAYBE SYNTHETIC GEAR OIL MIGHT HELP
Old Jan 7th, 00, 09:20 AM
kwissman kwissman is offline
Post
I have not done this myself, but I know of some drag racers that do this and they say it helps. Try adding some of the GM Limited Slip additive to the gear oil. The additive is super slippery and might help. It wont hurt anyting. I run sinthetic in my Muncie and it seems to shift ok at higher RPM. It may be that I am so wound up that I cant feel the difference, because I shift hard.
Old Jan 7th, 00, 04:19 PM
BillK BillK is offline
Post
67,
There has been an ongoing "discussion" about this over on Chevelle tech. I talked to the guys from Richmond gear a day or so ago and they recommended synthetic gear oil for thier manual transmissions but...it absolutely cannot be a gear oil designed for use with "Posi" type rears. The Mobil 1 75/90 is one which WILL work fine. The Richmond gear oil has a posi additive in it and should NOT be used in a manual trans. There is some friction required for syncronizers to work properly.
On another note, are you certain that your clutch is disengaging completely ??? This will also cause the problem you are having.
Hope this helps,
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Old Jan 8th, 00, 10:59 AM
Team Member
David
Thumbs up
Thanks for the input. I have replaced the old clutch with a centerforce dual friction set but have not tried it out yet, after close inspection, I believe the 2-4 shift stop screw was adjusted too close, not allowing the shifter to come back quite far enough, sounds stupid of me, but i simply overlooked it. I will be using synthetic fluid anyway, thanks again
67 RS
355, SUPER T10 4 SPD
9" FORD
Old Jan 8th, 00, 11:16 AM
Sureguy Sureguy is offline
Tech Team
Lightbulb
My friend uses Redline MTL in his SAAB 5 speed and those are not known to be stong. It works wonders for shifting and durability. Use it, you'll like it.
The night-time is the right time
****James Bondo****
Cars:'68 Camaro RS, '73 Porsche 914, '69 Datsun 510
www.whosnextracing.com
