69 Leaf Spring Eye Bushings install - Team Camaro Tech
Old Aug 11th, 08, 06:40 PM
69z28302 69z28302 is offline
Tech Team
Default 69 Leaf Spring Eye Bushings install
I am going to install the front leaf spring eye bushings on my car and was wondering if the flange goes toward the outside or inside of the car? Also, should you bottom the flange out or just center the bushings in the spring? The ones I removed were not bottomed out on the spring. Any help on this will be appreciated.
Thanks TC
Mike
Old Aug 13th, 08, 10:43 PM
Tech Team
Default Re: 69 Leaf Spring Eye Bushings install
I'm trying to attach a picture. I hope this helps.
Mike
Old Aug 13th, 08, 10:45 PM
RamAirDave RamAirDave is offline
Dave
Same thing I just posted on your thread on the CRG board:
I've found them to be installed left to right (both sides), the flange on the LH side. I think there is a pic in the AIM showing the same, but not sure if you can really count on that.
I don't think it really matters though, just center them in the leaf and you'll be fine.
Driving a #s-matching Z in the rain..... and lovin' it....
Old Aug 14th, 08, 05:42 AM
Z10396 Z10396 is offline
Both were toward the driverside on my '69 when I replaced mine.
Old Aug 14th, 08, 09:02 AM
Everett#2390's Avatar
<Jake 68's Rule
Driver side for both springs and flange against the spring eye.
Give a man a rescued dog for the health of his soul.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
