3858174 casting number on a 327 - Team Camaro Tech
Tag Team De-coding tags and numbers.
Thread Tools Display Modes
Old Aug 28th, 08, 05:40 PM
okiemark okiemark is offline
Mark
Default 3858174 casting number on a 327
well, I know this isn't from a Camaro? any ideas?
Old Aug 28th, 08, 05:46 PM
67 Plum's Avatar
67 Plum 67 Plum is offline
Chad
Default Re: 3858174 casting number on a 327
1964-67 3858174 327 275 350 2 Full, A & Y
275-350hp
2 bolt main
fullsize car Chevelle and Corve
Old Aug 28th, 08, 06:05 PM
Mark
chad: thank you... question: what is "A &Y". So, this motor could be desireable to a corvette owner? Is it either from a Vette or Chevelle? or, "fullsize car" as an option also. thanks again.
Old Aug 28th, 08, 06:17 PM
mike532 mike532 is offline
Got the pad stamp info ?
Here's what I've got
3858174 = 327 ,64-67 , 275-350hp ,car & Truck 2-bolt
Old Aug 28th, 08, 06:25 PM
Mark
Mike: I do, but not handy. I remember it looking crooked, and they used "I" where "1" should have been. I was told that was common at the Chevy plant. If I could get a decent price, I'd sell it. If not, this motor will be rebuilt to 383. just don't want to start messing with a motor that a corvette guy might want. I'll get the pad stamp tomorrow.
Old Aug 28th, 08, 06:53 PM
JohnZ JohnZ is offline
Team Member
John
The 3858174 block was used in '66 Corvettes, for both the 300hp and 350hp engines (assuming it's a Flint block - that's all that Corvettes used - they didn't use Tonawanda small-blocks).
JohnZ
CRG
'69 Z/28 Fathom Green
Old Aug 28th, 08, 07:33 PM
Mark
thanks JohnZ. how do I determin a Flint block? I'm still trying to put my hand on the engine numbers (stamp).
Old Aug 29th, 08, 07:13 AM
67 Plum's Avatar
Chad
A body Chevelle , Y body Corvette , F body Camaro , X body Nova and the other GM look alikes.Cutlass , Firebird etc.The front pad stamp will tell you what it is from.It isnt the best block to use for a 383.It is a small journal block and the crank costs more than the large journal ones.Also not as much room in the pan rails for the longer stroke.
Old Aug 29th, 08, 02:19 PM
The pad stamp will answer that.
Old Aug 29th, 08, 02:29 PM
Vintage 68's Avatar
John
Wink Re: 3858174 casting number on a 327
... how do I determin a Flint block? ...
Look for the small (1/8"npt) oil plug in the front (just right of center) of the block just above the timing cover - only Flint uses this galley machine process.
1968 Convertible
Some trucks
Other V8 things - some of which float
Other V6 things - none of which float
Oh yeah, and 1 "Straight-Six" ...
If a man says something in the garage - and his wife can't hear him - is he still wrong !!!
  #11
Old Aug 30th, 08, 12:54 AM
Mark
thanks john. I will take a look there. we just got the motor out. I saw a small "plug" but the guy said it was because it was rebuilt???
  #12
Old Aug 30th, 08, 05:26 PM
Team Member
John
All Flint small-blocks had the plug in the photo below, and Tonawanda small-blocks did not.
Click image for larger version
JohnZ
CRG
  #13
Old Sep 21st, 15, 12:31 PM
bob1967 bob1967 is offline
Bob
My 3858174 has stamping F0429YS. (Flint April 29). I can't see the cast date. Anyone know what this is? Thanks for any help.
  #14
Old Sep 21st, 15, 03:08 PM
click's Avatar
click click is offline
Moderator .. Jim
Jim
Bob start your own new thread so the info.of 2 cars doesnt get mixed up ok?
Click..is Jim..former owner of a 69RS-LM1 350/255 - 700r
Photos of my Camaro for viewing
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Tag Team      Current Topic: 3858174 casting number on a 327
Location
Location
First Name
Human Verification
