short or long water pump? - Team Camaro Tech
Old Sep 3rd, 08, 07:35 PM
brl67rs brl67rs is offline
Tech Team
Default short or long water pump?
i have a 67 camaro with a short water pump with a unversal long arm alternator bracket. i want to switch to a long water pump an new pulleys, will this cause a problem with clearance for the fan and shroud
Old Sep 3rd, 08, 08:36 PM
JimM JimM is offline
Jim
Default Re: short or long water pump?
All pre 68 chevy's came with a short water pump, and a driver side alternator.
69 and up used the long pump and pass side alternator.
The 69 shroud is an inch shorter. ALL the pulleys and brackets are different. And you have to move and rewired the alternator. The power steering brackets are different too. If you have a/c, it has to switch sides too.
Why would you want to change?
Old Sep 3rd, 08, 10:09 PM
TJS69 TJS69 is offline
Tom
Smile Re: short or long water pump?
If you want to get a different bracket and keep the short water pump, look at these brackets from Alan Grove.
http://www.alangrovecomponents.com/S.B.Short_Pump.htm
To emphasize what Jim said ALL pulleys and Brackets must be changed in going to a long waterpump.
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1
