| Team Camaro Tech Current Topic: Pressure and burnout length for BFG Drag T/A's? | ||
Qualcomm stadium runs 1/8th mile drags every Friday night, I'll be out of town this coming Friday, but the Friday after I get back I'm going to run.
My question is, what pressure should I run in my BFG Drag T/A's? 275/60x15's with 4:11 12 bolt posi, TH400 with 3,500 stall TCI converter and shift kit. Engine is a ZZ502. Have multi-leafs and KYB Gas-a-justs all the way around, aluminum radiator and battery in the trunk. Also, I've heard conflicting stories about burnout length, just spin them over a couple times to clean them off, or heat them up? Thanks, Mike a.k.a. 68SS502 ------------------ ZZ502, TH400 w/3,500 RPM stall and shift kit, 12-bolt posi w/4.11's. 3" Exhaust with X-pipe and 2 chamber Flowmasters. [This message has been edited by 68SS454 (edited 10-05-2002).] |
| Sponsored Links | ||
Advertisement | ||
Don't heat them up, the rubber that is left will not help traction at all!
I'd start at 20-22 PSI...what I do is pump them up to 20PSI, then do a short burnout (not holding the brake, just mash the pedal), get out and look at the tire marks. If they are uneven (cross-section), then you need to adjust the pressure. ------------------ 1969 Base Camaro Vortec 355, Perf. RPM, Demon Carb., TH-400 All sheetmetal is NOS GM See my webpage at: http://www.geocities.com/compuboy007/ |
I agree. I have had the best luck just cleaning them off.
bfg say that doing a long or extended burnout will ruin the tires effect, the tread will ball up and become slippery
I run Nitto drags instead of bfg (better life, and they are quite good in rain) and I've run as low as 16 psi ------------------ '68 Camaro (Baby) - 333, 200-4R, custom interior and paint, 12bolt going in soon '94 Z28 (Pepe) - stock heads/cam and 3.23 gears - 12.44 @ 106+ 1.68 sixty, all motor a few other toys some pics on the page: http://fastz28.cz28.com |
| Sponsored Links | |
Advertisement | |
