I need the vaccum hoses from the A/C control!! - Team Camaro Tech
Heating & Cooling Heating, cooling and air conditioning
Old Sep 14th, 08, 04:44 PM
POCKER POCKER is offline
David
Default I need the vaccum hoses from the A/C control!!
Hy Guys
I need the group of vaccum routing hoses that are connected on the A/C control valve and close the vaccums placed on the cowl pannel (Plenum valve), kick pannel, etc.
Those are for a 69 RS camaro.
Following the picture of what do I need: (thanks Thepartguy for the picture)
If some one know were can I find this please let me know.
thanks
David
Old Sep 14th, 08, 05:10 PM
DjD's Avatar
DjD DjD is offline
Dennis
Default Re: I need the vaccum hoses from the A/C control!!
Are you looking for a GM parts kit or hoses to be original? Since it's not visual I would think even in Venezuela you could find vacuum hose at the local parts store...
...Dennis
White Wonder
The Nova
Photo Album
www.camaroslimited.com
Old Sep 14th, 08, 06:08 PM
Z282NV Z282NV is offline
Joe
Originally Posted by POCKER View Post
Hy Guys
thanks
David
David, does the partsguy not have these hoses? ..he has a lot of A/C components.
http://thepartguy.com/mainACPARTS.htm
Z282nv........."its gotta be red"
http://s10.photobucket.com/albums/a130/z282nv/
Old Sep 14th, 08, 06:22 PM
DjD's Avatar
DjD DjD is offline
Dennis
When you look locally ask them to look under "emissions - hose - vacuum tube" I found lots of different sizes on www.rockauto.com under their extras catagory that way...
...Dennis
White Wonder
The Nova
Photo Album
Old Sep 15th, 08, 06:41 AM
click's Avatar
click click is offline
Moderator .. Jim
Jim
That area needs a special rubber 'boot' for lack of better word. The 3 hoses come together into this rubber boot and then do their job. The boot is NOT reprod that I know of either. The vac hoses can be anything close to same size you find at auto parts store, the connector will be your biggest issue. One hose opens and closes the diaphram up under the cowl vent opening on passenger side as well as the damper at the passenger's foot area. When you slide the switch, the vacuum is applied to different areas.
Click..is Jim..former owner of a 69RS-LM1 350/255 - 700r
Photos for viewing
Learn How To Post Pics here
Old Sep 15th, 08, 01:54 PM
Z06vette Z06vette is offline
Scott
Hey, I have it! I was trying to figure out what this was. I have the vac lines as well & the grommet that goes thru the firewall. The lines are good until you get past the firewall grommet. One line has a tee, but not sure what it goes to. I dont have the line off the tee. Its off my 69 RS camaro. You can contact me at grsdup1@aol.com.
Scott
69 RS LS1/T56 -now on the road
68 Firebird vert future project
67 LS1/A4 SOLD
