| Team Camaro Tech Current Topic: will it fit? | ||
| Camaro Tech General Tech Area For best results use specific forums |
hey guys, I've got a 5.7L engine out of a 1989 Chevy van. I've yet to look at the ID tag if its a 2 or 4 bolt main, but assuming its a 4 bolt, can this fit into a 67-69 camaro? I'm assuming that becuase they really didn't change the block a whole lot, all that may be needed at the most would be a different set of engine brackets...or am i smoking dope?
thanks -John |
| Sponsored Links | ||
Advertisement | ||
it will drop right in. Same motor mounts as regular sbc
1992 dodge stealth, base 1989 firebird T/A, ls1 swap 1991 z28 Camaro t-top 305 TPI -- sold 1967 Camaro project 468 c.i. th350 1984 Datsun Maxima wagon There are only 10 kinds of people in the world, those who understand binary and those who don't |
It will fit. You'll need to use the late type flywheel. They went to a 1 piece rear main seal in 86 and changed the flywheel at that time. The intake manifold for the 89 has slightly different angles for the center 4 holes where it bolts to the heads as well so you'll need a late style intake or swap the heads.
I'd check the oil pan to be sure it will clear and you will need motor mounts for a 67-69 Camaro, the ones from the 89 van will never work.
Jeff |
| Sponsored Links | |
Advertisement | |
