Dome light wiring - Team Camaro Tech
Thread Tools Display Modes
Old Sep 16th, 08, 06:30 PM
seeburg220's Avatar
seeburg220 seeburg220 is offline
Mark
Default Dome light wiring
My '69 is missing the dome light inside. The headliner looks like it's been on the car for a very long time, but obviously, it's not original, or there would be a hole where the dome light mounted. Anyway, can someone tell me which direction the wiring for the dome light comes from underneath of the headliner? I'm hoping the wiring is still there, and all I have to do it cut a small slit in the center. If I can verify that at least the wiring is in the roof, then I can proceed. Thanks - Mark
http://empinball.com/1969-camaro.html
1969 / 350 / TH350 / 3.73 posi / driver
Old Sep 17th, 08, 06:10 AM
Everett#2390's Avatar
<Jake-68's rule
Default Re: Dome light wiring
You might find/feel it left side of the dash going up the A-pillar.
Through the roof frame across top of door, then making a turn to the middle following the roof structure member.
White & orange wires.
Old Sep 17th, 08, 08:38 AM
madmax87's Avatar
madmax87 madmax87 is offline
On a 69 it comes up the sail panel and then across the center support panel of the roof. You can see the location of the wires in the pic.
Dennis
69 Z/28. 302DZ, Autogear M22, Red w/black stripes.
69 Camaro, ZZ4, 700R4, 8.5 3:42 posi, X11
70 Nova SS 396, 4sp, 3:55 12 bolt
Old Sep 17th, 08, 05:40 PM
Unreal Unreal is offline
Gary
Yeah, and I think you can get at the harness connection from the trunk. I think I have an extra, if it turns out yours is missing, and you want to fish one into place.
Old Sep 17th, 08, 07:08 PM
seeburg220's Avatar
Mark
Thanks guys for the pics and tips. I found a black and red wire set behind the left sail panel. I assume it's for the dome light, although obviously not original wiring, being the wrong color and location. I will chance it this weekend and cut into the headliner where the base is supposed to be and hope the wires are there.
Old Sep 18th, 08, 08:22 AM
click's Avatar
click click is offline
Moderator .. Jim
Jim
Remember the dome light needs full time power, not switched power. If your wire is only 'hot' when the key is turned "ON" then you dont want that one. You need a hot wire all the time, the spring switch in the door jab is the 'ground' connection.
Click..is Jim..former owner of a 69RS-LM1 350/255 - 700r
Photos of my Camaro for viewing
Old Sep 18th, 08, 03:06 PM
seeburg220's Avatar
Mark
Thanks Jim, I hadn't remembered that. I'm just hoping there are wires when I cut into the headliner
Old Sep 23rd, 08, 07:08 PM
Kev68ss Kev68ss is offline
Team Member
Kevin
Where are the dome wires on a 68- thanks
Old Sep 24th, 08, 01:25 PM
chuck69ss's Avatar
chuck69ss chuck69ss is offline
Chuck
For reference, here are a couple of more pics:
The wiring goes to the same harness that goes to the trunk on the LH side.
Chuck B
RI
69 SS Clone (from SS Donor car) - Frost Grn, x11, 350 4bbl, COMPCam XE256H, Crane XR-i HEI, M20, posi, Flowmaster 2.5";
'68 GMC C1500, Photo albums
You can live in your car, but you can't drive your house.
Old Sep 25th, 08, 08:35 AM
seeburg220's Avatar
Mark
thanks Chuck. Those extra pics helped. Looks like mine's not installed anymore.
  #11
Old Sep 25th, 08, 09:30 AM
chuck69ss's Avatar
Chuck
No problem, Mark... I was just thinking that you may be able to feel through the headliner to see if the wires are there at all. If not, I think you're stuck w/o a light unless you mess with the headliner. Of course you could always install one of these:
http://www.acehardware.com/sm-closet...i-1346625.html
Chuck B
RI
  #12
Old Sep 25th, 08, 10:52 AM
Gary
I installed a dome light for the correct look, but there's no bulb in it, cuz I did not want to run down my battery when the door was open.
You could install one w/o wires, and still get the correct look. BTW mine only has 1 screw in it as the other one would have cut right through a seam....didn't want the headliner to start unraveling!
  #13
Old Nov 26th, 08, 04:10 PM
brickyard02camaro brickyard02camaro is offline
Bill
This has proven to help me as well since I have the same problem. I have no headliner though and can see there is no wiring. Does anyone know where I can find the little plastic wire clips (retainers) that hold the wire to the roof? I have several broken. Of do you know of something else that will work?
Thanks to all of you.
Thanks,
Bill
1968 Camaro convertible, matching #s -for sale
1969 Camaro RS
1969 Chevy Truck
1971 Chevy Truck
1981 Elky
2002 Camaro, SS, Brickyard400 convertible. # 7 of 57 made = for sale
  #14
Old Dec 2nd, 08, 11:54 AM
chuck69ss's Avatar
Chuck
I'm thinking that I will drill small holes next to the slots and use small wire ties. I only have one of the original clips. You just don't want the wires to droop down onto the headliner.
Chuck B
RI
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Interiors      Current Topic: Dome light wiring
Location
Location
First Name
Human Verification
