Neutral Safety Switch wiring - Team Camaro Tech
Camaro Tech General Tech Area
Thread Tools Display Modes
Old Sep 20th, 08, 12:22 PM
98blackburb's Avatar
98blackburb 98blackburb is offline
Banned
Alan
Default Neutral Safety Switch wiring
I was going to take a picture before hand but I did'nt ...Will it work either way ?..Is this correct? Green wire up front ?
Old Sep 20th, 08, 02:21 PM
Banned
Alan
Default Re: Neutral Safety Switch wiring
Bump
Old Sep 20th, 08, 03:13 PM
Everett#2390's Avatar
<Jake-68's rule
Either way will work. Green & Pink are back-up lamps. Purple & purple/white is neutral safety switch.
Old Sep 20th, 08, 03:19 PM
Omaniac Omaniac is offline
Ulf
Perfect!
This answers my question about back-up lamps on another tread.
Great!
Old Sep 20th, 08, 03:50 PM
Banned
Alan
Thanks Everett , Nice 68 you have there,Please E mail me the ingredients for that 350 @ amccormick@cfl.rr.com
That is a strong 350 running those times.Thanks for the help. I feel better knowing it'll work.
Old Sep 25th, 08, 10:28 AM
Ulf
So I took the top cover off. I think I have a TH350 auto transmission, but there is no switch anywhere to be seen.
I've got those purple and purple white wires, but they disappear further aft under the center console. I actually thought they were for the light at the aft end of the console. From the same wire bundle I've got wires for the lights in the gear indicator, a ground wire, and a brown and a blue wire that has been cut, and are not connected to anything.
Any suggestions? Is the switch on this tranny located somewhere else?
And what does the neutral safety switch do?
Old Sep 25th, 08, 12:21 PM
1969ProStreetCamaro 1969ProStreetCamaro is offline
David
......the neutral safety switch prevents the car from being started while in any gear other than neutral or park.
"All I need is a fast machine". Steve McQueen
My Machine: 1969 Pro Street Camaro
468 CID 661 Horsepower Turbo 400
33"x19.50" Mickey Thompsons
Check Out My Camaro
661 Horsepower 468
Old Sep 26th, 08, 01:52 PM
Ulf
Thanks!
And nobody has a turbo 350 tranny and knows where the switch is located?
Old Sep 26th, 08, 02:21 PM
click's Avatar
click click is offline
Moderator .. Jim
Jim
I had the TH350 auto and console. A powerglide could also have the console. If the wires are there, then someone removed the switch. It mounts on the passengerside of the horseshow shifter at the base of it. The elec tabs on my switch are visible in this pic.
Click..is Jim..former owner of a 69RS-LM1 350/255 - 700r
Photos of my Camaro for viewing
Old Sep 26th, 08, 02:31 PM
Ulf
Something doesn't add up. I don't have a horseshoe shifter, only a stick type shifter.
Now, one way to check if the switch is connected is to put the gear into 3, hold the brake and start the engine. I know what happens if I do this on a manual, but if the switch is not there on a auto, what will happen? Will it start, or do I risk trashing the tranny?
  #11
Old Sep 26th, 08, 04:00 PM
2x67rs/ss 2x67rs/ss is offline
Andy
It shouldnt start. The switch should be on your shifter. If you try to start it and the switch isnt hooked up it wont hurt the tranny but make shure your foot is on the brake.
67 R/S convertible Nantucket blue deluxe interior orig.http://s63.photobucket.com/albums/h152/67ss/The%20pair/
67 rs-ss coupe 565BB-400turbo streetcar/racer project 1.43 60ft 9.683 140.91
http://www.youtube.com/watch?v=LFLC2...eature=channel
  #12
Old Sep 26th, 08, 04:35 PM
72camaross 72camaross is offline
Tech Team
Joel
cuz it is a nice surprise when it is left in reverse and you don't have that switch and the carb is cold so you got your foot on the throttle when starting it...oh my
Joel
68 Camaro SS project...slow project
  #13
Old Sep 27th, 08, 02:53 AM
Ulf
Tried and tested. Put it in reverse, and fired up the engine. It started, so no switch.
So I need to find a switch, figure out where the neutral switch wires lead, find out where my back up lamp wires are, and put everything together. I've got a long winter to do all that.
Don't know what I should have done without this site.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Camaro Tech      Current Topic: Neutral Safety Switch wiring
Location
Location
First Name
Human Verification
