Camaro Tech General Tech Area
Old Sep 21st, 08, 12:01 PM
kentsu kentsu is offline
Kent
Question Do you own a '67 or '68 with column shift auto trans (non-tilt)?
Hi,
I am doing some research on turn signal switches for '67 and '68 GM cars with standard (non-tilt/tele) columns. There were two types used. Most cars used a switch made by Delco but some used one made by Boyne.
I have established that column-shift auto trans Pontiacs without tilt (all body lines, including Firebird) used the Boyne switch in '67 and '68. I'm curious what switch was used on column-shift auto trans Camaros without tilt. Some helpful parts book snippets from John Hinckley seem to imply that these Camaros were different from their Pontiac brethren and used the Delco switch rather than Boyne.
If you have a '67 or '68 Camaro with column shift auto trans (non-tilt), please check to see which switch you have and post here. It's really easy to tell: Look at the hazard flasher switch knob on the right side of the column. The Delco switch knob is located near the bottom of the trim "cup" and has a square hole. The Boyne switch knob is located in the center of the "cup" and has a round hole.
You can click this link to see a picture of both styles. Delco is on the left and Boyne is on the right.
Thanks!
--Kent
P.S. I would be interested in knowing about ANY Camaro that has the Boyne switch installed, regardless of what trans and shifter it has.
Old Sep 22nd, 08, 02:54 PM
Arch Stanton's Avatar
Arch Stanton Arch Stanton is offline
John
Default Re: Do you own a '67 or '68 with column shift auto trans (non-tilt)?
'67 here.
I have Delco style according to your pics. (square)
Powerglide trans. Column shift.
- John
'67 V8 Camaro - 12637, 797-Z, M-M, 2M, 3K, 5Y
Old Sep 22nd, 08, 05:07 PM
keypilot keypilot is offline
Mark
x2
Don't stop now!!!
67 camaro driver
383 10:1
Horsepower:
483 @ 5,500 rpm
Torque:
499 lb-ft @ 4,800 rpm
www.firstgens.com
Old Sep 22nd, 08, 06:25 PM
murph's 68 murph's 68 is offline
Mike
X3 but 68
Old Sep 22nd, 08, 07:34 PM
butternutz68 butternutz68 is offline
Team Member
Wayne
Mine is Delco style, 1968
Old Sep 22nd, 08, 09:03 PM
captcanuck68 captcanuck68 is offline
Ted
Delco here as well.
capt
bumper sticker:HONK if you love Jesus!
TEXT while driving and you'll meet him!
Old Sep 23rd, 08, 06:52 PM
meusebi meusebi is offline
Tech Team
2 68 Camaros norwood cars one two speed power glide other 4 speed both Delco
Old Sep 23rd, 08, 09:00 PM
Bowtie707 Bowtie707 is offline
Eloy
Mines Delco Also
Old Oct 3rd, 08, 10:38 PM
Kent
Thumbs up Re: Do you own a '67 or '68 with column shift auto trans (non-tilt)?
Thanks everyone! I think your responses pretty well confirm that the Camaro used the Delco switch and never the Boyne switch, whereas the Firebird used the Boyne in one case (column-shift AT).
I have updated the article on my web site:
http://www.corvairkid.com/67-9signal.htm
The article is primarily about converting from a Boyne to a Delco switch but I have added quite a bit of info about the diversity of parts and applications.
--Kent
