New bests, distributor picked me up - Team Camaro Tech
Old Sep 22nd, 08, 10:42 AM
Greg O Greg O is offline
Default New bests, distributor picked me up
Thanks to John Calvert's advice I finally have the car hooked up and am getting some good data (went from 17 to 21lbs. on the Drag Radials).
I swapped out my stock GM HEI a month ago for a Pertronix set-up and thought it picked me up but needed more data to confirm it. Well, this weekend we got some better air and the distributor has definitley picked me up. My guess is about .05 which really surprised me.
My old bests in my signature were on a day the DA was -250ft. Friday the air was 980ft.
1.471 60ft.
7.073 @ 96.486
The NHRA correction factors show about a 6.99-7.00 at sea level so I am looking forward to some even better air in October!
69 Camaro, 3450lbs., 406, Cal Tracs, Coan 10", 3.73 gear
D1SC blow thru, pump gas, 9.3:1, ~8 PSI,
1.319 60', 6.005 @ 115.4
Old Sep 22nd, 08, 10:50 AM
6D9 6D9 is offline
Ron
Default Re: New bests, distributor picked me up
Nice Greg! That sucker really moves out.
69 Camaro
491/AFR 315'S/XR286R
TH400/GV OD
9" 3.50
Old Sep 22nd, 08, 12:51 PM
Dougs72Nova Dougs72Nova is offline
Team Member
Doug
That car does scoot! Congrats.
Old Sep 22nd, 08, 01:19 PM
DOUG G DOUG G is offline
RedЯuM
Congrats. 7.0 1/8 = 11.0 (approx)
I guess this shows I need more converter ?
68 Camaro~ LSx
RedЯum <-Pics
http://www.youtube.com/watch?v=Of8WV...ature=youtu.be <~More here
Old Sep 22nd, 08, 01:36 PM
6D9 6D9 is offline
Ron
Yeah but he is trapping 96+ mph in the 1/8. But I think you would pick up mph if you had more converter cause that new cam you have is pretty stout!!
69 Camaro
TH400/GV OD
9" 3.50
Old Sep 22nd, 08, 01:59 PM
Steptoe Steptoe is offline
Steps
So what is the difference in the curve between the 2 dizzys?
Old Sep 22nd, 08, 03:33 PM
Fred Ficarra Fred Ficarra is offline
Fred
Ready to take notes,,,,
One owner 69 Camaro,(yep, bought it new)
RS SS Hugger Orange, L88, 4:10's tru-tack posi, ducted hood, Endura, spoilers.
TH400 (CX) GV with Coan 8" converter, GV-OD, 8 track still on console and best et 10.617, 126.45mph 1.478 60'
All with 1960's stuff. (except tires and converter)
+ MT Super Scavenger headers.
1000cfm AED and HD Harold-Lunati SR, 725 lift with shaft rockers too.
http://epitomesrebuild.com/
Old Sep 22nd, 08, 06:50 PM
The old HEI had a welded up advance so it had 38 degrees from the turn of the ignition. I had to wire in a cutout switch to crank it.
The new dizzy has real loose springs with about 25 degrees at 1000 RPM and a full 38 by 2000.
Old Sep 22nd, 08, 06:51 PM
ace's68 ace's68 is offline
AJ
Glad someone is having luck with the pertronix ignition system, haven't got mine figured out quite yet.
The only Mustang I'd ever own is a Fender.
Old Sep 22nd, 08, 07:06 PM
40Coupe 40Coupe is offline
Congrats on the new best.
N/A 468, 275/60 drag radials
3500 lbs
1.33 (1.31 best)
6.05 @ 112.73
9.55 @ 140.25
Videos
http://www.youtube.com/watch?v=lUq07aTZ5mg
http://www.youtube.com/watch?v=TrLxwZbd8A8
Old Sep 22nd, 08, 08:53 PM
Lonnie67 Lonnie67 is offline
Good job Greg
67 Camaro daily driver 11.64, 115.95mph, 7.40@93.37, 1.63 60ft 383/3.42's
67 Camaro strip/street 4?? under construction... forever
webpage
Vids
Old Sep 23rd, 08, 04:55 AM
Eric68 Eric68 is offline
Eric
Good job Greg
What do you think it was with the distributor that caused it to pick up? Something wrong with the HEI?
E85 racer and E85 carb builder
www.horsepowerinnovations.com
68 Camaro, E85 powered 427" small block. 9.96 @ 133 MPH, 1.319 sixty foot on motor. 5.92 eighth @ 116 with a 1.42 sixty breaking beams with back tire on the bottle
Old Sep 23rd, 08, 05:55 AM
Ace, what kind of problems are you having? Did you buy the complete distributor?
Eric, I don't really know. The old HEI had a stock module and coil but it never "missed" so I can't figure it out. You hear that stock HEI's will drop off after 4500 RPMs but I assumed that meant it would start skipping or something. Maybe it just could not provide a strong spark at the higher RPMs?
The only reason I switched the distributor is I got tired of the kill switch thing so I was real pleased that it picked up.
Looking back, a buddy of mine switched to a Pertronix about 2 years ago and his car seemed to pick up. He didn't really track DA and e.t.s so much so it was just anecdotal evidence but I guess it's safe to say he had similar results.
Old Sep 23rd, 08, 07:30 AM
Eric
Well, a strong spark will never hurt you -- that's for sure. I wonder if the HEI had a retard or fluctuation in timing at high speed.
Old Sep 23rd, 08, 07:24 PM
Steps
I have had several HEI s up on the osiliscope over the yrs, get up around the 5500+ and the waves start to show signs of inconsistancy..
Or it could just be a bit worn in the bushes.
The HEI was not a pure track dizzy, but a damn good street unit.
Right tool for the right appilcation.
