Tools & Shops Shop Rat HQ
Old Sep 23rd, 08, 08:00 PM
rodutah rodutah is offline
Tech Team
Default fluorescent lights
I'd like to add some to the garage. Only requirement is that they can start up easily in temperatures down to about 32f. I am not looking to spend a ton. I'd prefer 4ft fixtures. I'm not sure what size bulb wattage would be best. I have seen the cheapos at the bix box stores, not sure if they'd cut it in the cold weather.
68 Camaro Coupe
Old Sep 23rd, 08, 08:40 PM
Larry B Larry B is offline
Larry
Default Re: fluorescent lights
I've used all type of fluorescent lights in nebraska I like the 4ft bulbs but use the little screw in 200 watt at work in the winter a dark to start with but thay do warm up and it dose get cold in nebraska like 60 below
Larry
Old Sep 23rd, 08, 09:09 PM
Rocketrod Rocketrod is offline
I just recently went down this path. I ended up buying three Sylvania Super Saver compact flourescent light (CFL) bulbs that were 200W replacements that use 65W each. The light output of each CFL is 4200 lumens compared to the 700 lumens output from the bulb they replaced. My garage is 21' x 31' and painted a light tan (walls & ceiling), but when I turn on the lights it is like I drug the sun into my garage. Each bulb cost me $18, which was much cheaper than buying shop lights fixtures and bulbs, plus it took less than ten minutes to install the new bulbs.
Rod
69 Camaro - 355 SBC, 2004R, 12 bolt posi w/ 3.73, Baer 4WDBs w/ Hydraboost, Hotchkis & GW susp, Budnik Cobalts, Marquez Design pieces, DSE dash & Billet hood hinges, Corbeau TRS seats...
Smoothing firewall and Upper dash panel replacement
Old Sep 23rd, 08, 09:10 PM
yellow69RS's Avatar
yellow69RS yellow69RS is offline
Jeff
I have the zero start four foot from the big orange box, they do OK here in the Chicago winters. The garage is not insulated and they do sometimes seem a little dim for a short bit.
Jeff
Old Sep 24th, 08, 07:35 AM
Lost in the 60's Lost in the 60's is offline
Mitch
I have 4 eight footers that I bought from Menards. They are Sylvania rated for low temps. I keep the shop at 38 degrees all winter and they come on right away and are full brightness.
67 Camaro ss/rs...http://rides.webshots.com/album/557974721HYToph
67 GTO.....
was supposed to be minimal rust....http://good-times.webshots.com/album/569074780LSqNwG
69 K15..it's a Chev spelled with 3 letters...
70 Chevelle...built in Sept 69...http://rides.webshots.com/album/568736081wfXHNB
Old Sep 24th, 08, 10:31 AM
zuma's Avatar
zuma zuma is online now
Gold Member
Mike
There are low temp or zero temp ballasts out there on the market for T-8's... Stay away from T-12's they are being phased out... just give an electrical parts house a call and they should be able to hook you up....good luck...
(In God we trust. Everyone else, keep your hands where I can see them).
1969 Camaro
1990 IROCZ28 convertible
2004 Silverado Z71 4x4
GGSMU member
http://www.ggsmu.com/
http://community.webshots.com/user/michaelmontanez
Old Sep 24th, 08, 06:13 PM
68Holdon 68Holdon is offline
Robert
I have found that the cold start units also tend to be a little noisy.
There are no problems only solutions
68 Camaro, RS/SS, ZZ502, Retrotek Fuel Injection, 4 Speed.
2010 RS/2SS Black, 6 speed trans
Old Sep 24th, 08, 08:47 PM
zuma's Avatar
Gold Member
Mike
Usually the new electronic ballasts do not generate much if any noise at all, the old magnetic type sometimes had a problem with that...
1969 Camaro
GGSMU member
Old Sep 24th, 08, 09:56 PM
sdphilips sdphilips is offline
Scott
i put up some 4ft ones in my shop, western nebraska, with the electronic cold start ballasts...worked fine last winter even on the coldest days. They did take a bit to "warm" up to full brightness.
Scott
68 Coupe
Old Sep 24th, 08, 10:56 PM
Vintage 68's Avatar
John
Thumbs up Re: fluorescent lights
I'll second the "T-8" with transistorized ballast recommendation
I have a place in the mountains and they will start at well below freezing every time.
Replaced a bunch of older incandecent fixtures with the newer CFL and t-8's over the last few years with no problems what-so-ever.
Most folks don't know that the standard incandecent bulbs we have are being phased out over the next 10~12 years - through some legislation that passed a year or so ago.
The newest bulbs on the market are LED's for standard home fixtures. I recently installed a couple LED Flood Light bulbs at our mountain place. They draw a WHOPPING 3.5-watts and put out 175-watts of light in the 3000k-deg. range (a nice warm white light). Their life expectancy is in the 15~20 year range, if you use them all the time
The cost is way up there - the Floods were @$65 each - but they will save me that much on my bills in a few years ...
The standard 100/150-watt (draw @2~3-watts) bulbs like this one
Click image for larger version
Name:	LED lamp for standard house fixtures.jpg
run in the $50 range right now - but the prices are dropping fast and they power companies have all announced plans to furnish them through local outlets at much reduced pricing in the near future, like they do the CFL's now.
Our grandkids probably will never know who Thomas Edison was ...
1968 Convertible
Some trucks
Other things - some of which float ...
Eagles may soar - but Guinea's don't get sucked into jet engines ...
It's never to late - okay, maybe now it is ...
WE NEED MORE COW BELL !!!
