methanol injection - Team Camaro Tech
Old Oct 6th, 08, 04:51 PM
dawg's Avatar
dawg dawg is offline
Harry
Default methanol injection
looking for a complete kit for naturally aspirated carbed engine.
seemes to have alot of benifits.
Dawgs 69
406 stroker
us navy retired
http://www.northeastf-bodyassn.com/
Old Oct 6th, 08, 05:30 PM
ace's68 ace's68 is offline
AJ
Default Re: methanol injection
Summit racing sells them, probably the most reasonable price. I believe there about $422.00
You prob wouldn't see much benefit unless you have a HIGH compression or a load, or a combination of the two.
It's used to prevent detonation in most cases, especially back in world war 2 on the super charged air craft engines.
The only Mustang I'd ever own is a Fender.
Old Oct 6th, 08, 05:48 PM
thedugan's Avatar
thedugan thedugan is offline
Doug
I'm using this kit from DevilsOwn on my EFI motor.
http://www.alcohol-injection.com/wat.../universal-19/
-Doug
68 RS/SS Conv
Restoration started 5/2007.
Have it for 08 nope
Have it for 09? nope but it runs and moves
Have it for Spring 2010?
http://www.facebook.com/thedugan789
Old Oct 6th, 08, 07:16 PM
camaroman7d camaroman7d is offline
Royce
You should also check with Alcohol Injection Systems. They have trunk mount systems, this is the system I have on my car. There is also a lot of good information on their site.
Royce (NO XQSSS) Bradley
www.facebook.com/driveyourjunk
http://www.youtube.com/watch?v=DSLsGgDjFXE
(brief sound/video clip, 3 1/2" exhaust through Borla Sportsman mufflers)
Old Oct 6th, 08, 09:27 PM
dawg's Avatar
Harry
I can definately use methanol injection
engine is at 13:1 compression static
tired of using 110 or 116 leaded race gas al the time.
Dawgs 69
406 stroker
us navy retired
Old Jan 9th, 13, 07:19 PM
omalley1537 omalley1537 is offline
Tech Team
Sean
I have been looking into this but I had a question. I talked to Snow Performance and they said that on an NA engine, injection doesn't typically start until between 2500-3500 RPM. On a high-compression NA engine, wouldn't detonation have started long before that if it was an issue? It seems like total timing would have already been in for 500-1000 rpm by then, and the whole point of the kit would be to be able to run pump gas with high compression and respectable timing numbers. Can anyone enlighten me on this issue?
1969 Z28 Clone/383 Under Construction/Holley #4779 750DP)/Tremec TKO600/Dutchman 9"/Poly Subframe Mounts
Old Jan 10th, 13, 01:56 AM
Eleanor's Nemesis Eleanor's Nemesis is offline
Michael Gekko
Harry, are you talking about a methanol inj system to augment your current set up or are you wanting to switch from a gasoline burning engine to alky? Reading your post you said you are tired of buying the $$$ race gas.
Have you looked into an E-85 set up? Check out one of our member's sites-horsepowerinnovations.com...his name is Eric, builds E-85 carbs. I know you are looking for injection set ups but the carb deal may be more interesting.
Methanol is going to be harder on the engine than ethanol. For a race car that gets frequent rebuilds it isn't a big deal really, but for a street car or street/strip car it may be.
Between the wear factor and the reported hard starting with alky injection some of the guys that race around here use a gasoline primer system to start the car and idle around the pits and such. When they get in the burnout box they flip the switch over to alky and let it rip. Just can't go over about 2000 rpm on the gasoline primer.
I would check out the site Royce listed...also check out Killerrons.com. Lots of racers use Ron's alky injection system, they are the guys that came out with the 'Ron's Flying Toilets' years ago.
Also, with the alky deal you will have to change the oil more frequently and take precautions so you don't 'Milk the oil'...have to get the engine up to temp before shutting it down and etc....and some oils definately don't jive with alky. Lots of alky racers use Brad Penn oil for this reason.
1968 Camaro NHRA/IHRA SS/C 'Super Stocker' 396/Jerico
1968 Street/Strip Camaro 350 w/PG
1968 Caprice NHRA/IHRA Stock ELiminator O/SA 327-250 HP
Land of the Free Because of the Brave
It Takes a Long Time to Grow Old Friends
Old Jan 10th, 13, 05:03 AM
zdld17 zdld17 is offline
Don
If you are looking at preventing detonation only, won't the old water injection system work? It was used long ago.
Don
TC # 349
Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E
http://s102.photobucket.com/albums/m...t=115_1577.jpg
Old Jan 10th, 13, 08:05 AM
Tech Team
Sean
I was referring to water/methanol injection/ADI as sold by compaines like Snow performance and AIS. I assume that the OP was as well (if not, my apologies for jacking the thread). My big confusion is that they advertise being able to use their setups for controlling detonation on a high-compression NA engine without using race gas/octane supplements. However, Snow told me that the injection can't come in much earlier than 2500-3500 (and he leaned towards the 3000-3500 range) due to the tendency for the mix to "put the fire out" so to speak in the cylinders and cause a misfire. At that RPM it seems like detonation would have become an issue before the unit kicks in, defeating the purpose. I am sure I am missing something, and was hoping someone knew what.
Old Jan 10th, 13, 10:32 AM
Don
You probably have recurved your dist to keep from going over total advance? I am running 17° at crank and 37 total. Looks like your are running a little more compression and cam than I am. I am also running a .035 quench.
Don
TC # 349
Old Jan 10th, 13, 04:26 PM
1SLOW64's Avatar
1SLOW64 1SLOW64 is offline
jeff
i made my own for my grand national. used nos jets.....went from 15# of boost to 23#'s using over the counter rubbing alcohol.
CURRENT PROJECT: 1969 X66 RALLY GREEN/BLACK COMFORT WEAVE, OWNER INSTALLED RS PACKAGE
1987 BUICK GRAND NATIONAL SOLD
2002 C5 coupe Electron Blue 1 owner FOR SALE
FUNDING THE X66 BUILD
Old Jan 10th, 13, 04:28 PM
1SLOW64's Avatar
jeff
read>>>>> http://www.turbomirage.com/water.html
Old Jan 10th, 13, 08:43 PM
ron498 ron498 is offline
Ron
1Slow,
Have you used this on an NA setup? Would need to trigger it off lack of intake vacuum rather than boost.
My LS1 is running 11:1 CR and the fuel around here is E10 crap. Would be nice to add water/meth so I can run more timing especially in the summer.
Cool thing about the GM EFI is it senses knock, so it will be easy to measure the effectiveness as well as retune the AF ratio.
Ron
498" 69 Nova
Pump Gas, full exh, driven to the track
9.91@133.63 N/A best W/4.10's
9.41@143 150 shot W/3.73's
2000 C5 Corvette Auto 11.10 @ 122.8 NA
I'll be back for you Jack, and I'll let the machine speak!
