Old Dec 10th, 99, 04:19 PM
RickB1B RickB1B is offline
Default
I have a stock 67 camaro with stock 327 in it. I would like to up the power to a good all around street driving car. I am considering puting in some new GM vortec heads. Is there any gotchas with doing this or is it a straight bolt in. Thanks in advance Rick
Old Dec 10th, 99, 04:32 PM
MarkM MarkM is offline
Default
Vortec heads look great, I've seen two magazines put these heads on a 350 and got around 370 hp. They are cheap too, complete scoggin dickey sells them for $400. You will have to buy an intake manafold dedicated for this style heads. good choice.
Old Dec 10th, 99, 05:03 PM
1st & 2nd GENGuy 1st & 2nd GENGuy is offline
Default
Jim Pace GM Parts Warehouse has an ad in the January 2000 Car Craft advertising vortecs for $418 and a drilled version (86 and prior manifolds) for $478. www.paceparts.com or 1-800-748-3791.
Good luck!
Old Dec 10th, 99, 05:04 PM
Default
Good luck!
PS while you repalce the heads consider a cam also.
Old Dec 22nd, 99, 04:56 PM
gregmontgomery gregmontgomery is offline
Post
if your going to replace the heads replace the cam also take advantage of the potential of the heads.
Old Dec 23rd, 99, 07:52 PM
josh_sallee josh_sallee is offline
Tech Team
Post
i think you have to use the self-aligning rocker arms with those heads. but i have also heard some impresive things about those vortec heads.
josh
Old Dec 24th, 99, 09:59 AM
DOUG G's Avatar
DOUG G DOUG G is online now
Post
Josh is correct about the special rockers,and yes for an extra exspence you get them drilled for old style intakes.
[This message has been edited by DOUG G (edited 12-24-1999).]
Old Dec 26th, 99, 03:49 AM
Vitriol Vitriol is offline
Tech Team
Post
If you can afford it though, I'd go with the Vortec-style intake (Performer or RPM etc.) since they are port-matched to take full advantage of the heads, moreso than the older intakes.
Old Dec 26th, 99, 12:54 PM
Doug Garland Doug Garland is offline
Exclamation
I saw a price breakdown on the Vortec heads on the Team Chevelle page, and after getting the heads, G.M. intake, rocker arms, valve covers, and all the things to put them on with,you could have over $800 in them.Not as good a bargain as they seem, but they do flow well from all the charts I have seen. Just thought you should know.Click below:
www.chevelles.com/forum/Forum1/HTML/001933.html
[This message has been edited by Doug Garland (edited 12-26-1999).]
Old Dec 29th, 99, 05:24 AM
Tech Team
Post
Not as good a bargain as they seem? Let's not be misleading here. If someone is doing a *complete* rebuild, replacing all those parts in the process, it is a great bargain. However, if someone wants to just upgrade their heads, it is probably not the way to go.
Old Dec 29th, 99, 06:47 AM
sixtsevnssrs sixtsevnssrs is offline
Tim
Post
I am not to familiar with the vortec heads but if I were going to spend that kind of money I would definatly look into the Edelbrock aluminum heads or something like the trick-flows twisted wedge, some really good heads. I have a set of the Edelbrock Performer RPM's and would not trade them for anything.
you have not mentioned which heads that you have. Just stock. If they are the camel hump heads you allready have an excellent set of heads. cast numbers ending in 461 or 462 I believe are the ones to look for. I think the 461's are more desireable being the 2.02/1.60 valves instead of the 1.94/1.50 valves. With some machine work these heads with there 64cc chambers are real power makers. Machine work needed would be port and polish, triple angle valve job, screw in studs, z28 style springs and some good rockers, dont forget the hardened valve seats, some good valves. But by the time you get all this you could of had something like the aftermarket aluminums, which give you a weight savings as well, with the machine work already completed.
Either way you will add some extra ponys to your Camaro. Performance costs, bottom line. What you want to do is the question.
Just my couple of cents worth.
Tim
67 ss/rs, MODIFIED
http://www.geocities.com/motorcity/speedway/6792
IM - sixtsevnss
Old Dec 29th, 99, 08:38 AM
Tech Team
Post
I see your point Tim, but it's really no comparison for someone who wants to upgrade/rebuild everything.
Vortec heads, gasket, rockers, intake, valve covers, carb, water pump, etc etc for $1000 OR
one pair of (bare?) Edelbrock aluminum heads $1000
Possibly an entire engine rebuild or just the heads, take your pick.
Old Dec 29th, 99, 11:51 AM
Post
Edelbrock perfromer rpm heads are sold complete, and are under 1k.
Old Dec 30th, 99, 05:41 AM
Tim
Cool
V, I do like the rides that can blast from 0-60 in 5 seconds and if you can do that with a stock look then thats awsome.
Mark, Edelblrock makes so many different packages for their aluminum cylinder heads it would make your head spin.
BB or SB, angled plugs or straight, bare or complete, 64cc or 70cc chambers, regular performer or RPM performer, or torker or whatever, new style heads for 86 and up, corvette style, 23 degree heads for the SB2 block, and thats just Chevrolet. They have there hands in just about everything right now. Hell I think they have an aluminum cylinder head for my 5 hp briggs & stratton on my lawnmower. Well maybe not. But you are all right, and some great advice has been shared, but the decision on what to do is up to Rick.
If it were me I would put a blower on it with some big meats and just have fun.
Tim
67 ss/rs, MODIFIED
IM - sixtsevnss
Old Dec 30th, 99, 12:58 PM
Crash Crash is offline
Tech Team
Question
I too am in the middle of this problem.I presemtly have 305 heads on my 350.Now do I go with a recondition set of double humps($700 cdn) or get a set used but not done yet($200) or I can get a set of 462 castings for $100 and work them over for another $400 or get a set of vortecs for $600 but need another intake. The possibilities seem endless. I've seen in recent articles how the Vortecs flow but does anyone have an idea how a set of 462 with 3-angle,ported and other good stuff added to them might flow?
