70 Z28 Backdrive Rod Numbers - Team Camaro Tech
 Ground Up Restorations
Second Generation 1970-1981
Thread Tools Display Modes
Old Nov 3rd, 08, 02:29 PM
rszmjt rszmjt is offline
Mike
Default 70 Z28 Backdrive Rod Numbers
Does any TC members know the lower reverse backdrive rod stamped number for a 1970 Z28 4 speed, or the length?
Thanks in Advance.
2002 Jerry Bickle Cavalier, 446" Small Block, Brodix Canted Valve, lenco 5 speed, 7.54 @ 180. mph,1.06 60', 2235 lbs for 2014. GM Canada Docs, Highly Optioned 69 RSZ28 , Hugger Orange, White Stripes, 42,000 mile survivor, owned since 1973.
Old Nov 3rd, 08, 09:31 PM
Z15CAM Z15CAM is offline
Ron
Default Re: 70 Z28 Backdrive Rod Numbers
Do you mean the "Reverse Shifter Rod" and number stamped into it? If that's what you mean I could crawl under mine and have a look - LOL
Z15CAM - There was a Viper in my Rear View
This was my 70 1/2 Z28
http://www.flickr.com/photos/28082975@N04
Old Nov 4th, 08, 10:56 AM
Mike
Ron, Thanks for the reply. Actually I was looking for the lower rod that goes from the rev trans tag to the backdrive bellcrank assembly on the side of the subframe. If you would not mind looking for the stamped number or even a total length measurement , it would be very appreciated.
I am working on a friends 70 Z28 and the lower backdrive rod he has seems too short, unless he has the wrong rev tag on the trans. Is your reverse tag the wider one with the hole forward for the lower backdrive rod?
Many Thanks. Mike.
Old Nov 4th, 08, 01:38 PM
twozs twozs is offline
mike
this is off my 73 z if no one else posts ill get a # off of it but this is the part your talking about, right? I'm pretty sure its the same part # first shot is from the top second is from the bottom at a weird angle.
Old Nov 4th, 08, 01:54 PM
mike
Old Nov 4th, 08, 05:05 PM
Ron
Whoa! I call that the Reverse Lock Out Linkage. I had to take that out of my car to install Headers and I bolted up the lever on the Steering Column to prevent the Column from accidentally locking; fortunately I still have it. Give me a day or two to located it.
Old Nov 6th, 08, 12:13 PM
Mike
Thanks for all the replys.
Z15Cam, that would be great if you can find it and post some pictures also.
twozs Thanks for posting the pictures.
Old Nov 8th, 08, 06:39 PM
mike
sorry thats actualy for the 3 speed heres the muncie 4 speed
Old Nov 13th, 08, 05:17 PM
Ron
Been looking for that Box but just can't seem to locate it right now; however, I see Mike has provided the Diagrams. Nice work Mike.
Old Nov 14th, 08, 12:18 AM
Mike
Thanks for all the help guys, I appreciate it. Mike.
Team Camaro Tech > Generation Specific Forums > Second Generation      Current Topic: 70 Z28 Backdrive Rod Numbers
Location
Location
First Name
Human Verification
