GM Performance Parts ZZ427/430HP Engine - Team Camaro Tech
Thread Tools Display Modes
Old Nov 7th, 08, 05:54 PM
rsb0719 rsb0719 is offline
Robert
Default GM Performance Parts ZZ427/430HP Engine
What do you think about this GM engine; do you think it worth the cost or could one be built for a cheaper price? Cost varies from $10,000 to $12,000.
Outstanding Performance
Even on Low Octane Fuel
Few engines conjure thoughts of greatness like the legendary Chevy big block 427. It powered some of the most storied cars in high-performance history. New to the GM Performance Parts lineup, the ZZ427 crate engine maintains the good, original characteristics while adding modern touches: updated 4-bolt main cast iron block, forged internal rotating assembly, 10.1:1 compression ratio, and aggressive hydraulic roller cam. The engine's top half is the same as the Limited Edition Anniversary 427; the intake is a matching high-flow oval port aluminum piece. With 444 ft/lbs torque and a conservative 430 HP rating, this is still one of the best crate engines for nearly any big block application.
SPECIFICATIONS
Engine Type: BB-Chevy V8
Displacement: 427 ci
Bore x Stroke: 4.25" x 3.76"
Block: Cast iron with 4-bolt main caps
Crankshaft & Connecting Rods: Forged steel
Pistons: Forged aluminum
Camshaft: Hydraulic roller
Valve Lift: .510 Intake/.540 Exhaust
Camshaft Duration @ .050": 211 Intake/230 Exhaust
Cylinder Heads: Aluminum oval port, 110cc chambers
Valve Size: 2.19 Intake/1.88 Exhaust
Compression Ratio: 10.1:1
Rocker Arms: Aluminum roller, 1.7:1 ratio
Distributor: HEI
Carburetor: 870 cfm
Water Pump: Aluminum, short
Spark Plugs & Wires: Included
Flexplate: 14"
Ignition Timing: Base 8 BTDC, Total 36
Maximum Recommended RPM: 6000
Balanced: Internally
Recommended Fuel: 92 octane
Old Nov 7th, 08, 08:12 PM
pdq67 pdq67 is offline
Banned
Default Re: GM Performance Parts ZZ427/430HP Engine
If I wanted a ZL1, I'd make it at least 12.0 to 12.5 to 1 and run rect heads on it and a knarly solid lifter cam just like they were!
W/ uncorked headers, it is worth about 530 to 540 hp up top!
Hell, you are probably paying at least $3,000 for the name alone!
pdq67
Old Nov 7th, 08, 08:28 PM
wildman926 wildman926 is offline
Walter
All you need is a 396 crank, 427 pistons, and a 454 block, and you have your own 427, much cheaper. Throw some 781/049 heads, a solid ft cam, and you will make way more power than that motor, and 1/3 the cost.
Walter
69 Chevelle SS
10.5-1 496/AFR 305's/Voodoo 60234 Solid Roller/TH400 4000 Stall/4.11 12 Bolt
http://s150.photobucket.com/albums/s86/wildman926/
Old Nov 7th, 08, 11:58 PM
Robert
Red face Re: GM Performance Parts ZZ427/430HP Engine
I guess you both are right; go out find season block and go from there. It would be a lot cheaper.
Old Nov 25th, 08, 10:04 AM
WES 1967 yenko clone WES 1967 yenko clone is offline
WES
Just be careful what you do.I had a motor for sale on this site a 427 like was just talked about. It was complete air cleaner to pan fan clutch to bellhousing and i could not sell it for5000.00 cdn which is alot less US.It made almost 500hs/500torque. So just be careful, i was told by one of the members here it was only worth 1500.00?,and i have way more than that!
Take Care Wes
Old Nov 25th, 08, 01:36 PM
69 z11 69 z11 is offline
Jerry
Does anyone know if the new crate 427 has a provision for a mechanical fuel pump or not?
69 Z11 03D Van Nuys
82 Z28 Gordon Johncock's Pace Car
97 30th Z28 6 speed vert 1 of 175
A Pair of Huggers at the Car Show
Old Nov 26th, 08, 09:51 PM
Robert
Yes, it has provision for a mechanical fuel pump.
Old Nov 27th, 08, 09:53 AM
Dave69Z Dave69Z is offline
I wanted one of these motors but they seem way over priced.
Old Nov 29th, 08, 06:05 PM
Robert
Angry Re: GM Performance Parts ZZ427/430HP Engine
Yes, it is over priced; can't understand why they would want so much money for an engine that they probably built for 5 to 6 thousand and it 's not the ZL-1.
Old Nov 30th, 08, 09:21 PM
Jerry
Thanks! So is it a Mark IV block?
69 Z11 03D Van Nuys
  #11
Old Dec 1st, 08, 01:19 PM
Robert
This engine is base on the original 427. Check out this site.
http://paceperformance.com/index.asp...&ProdID=226857
  #12
Old Dec 1st, 08, 01:57 PM
Jerry
Yeah, that's just the standard Chevy PR stuff. Doesn't get down into the detail, like one piece or two piece main seal, fuel pump number, compatibility with MK IV parts or not. I want to put a 427 in my 69, but I want it to look stock so I need to know if a 69 quadrajet intake will bolt up. What I would really like to find is a complete Corvette 1969 L39 engine, a 427 390 hp motor.
69 Z11 03D Van Nuys
  #13
Old Dec 2nd, 08, 12:38 PM
Fred Ficarra Fred Ficarra is offline
Fred
My L78 came with an aluminum high-rise and a Holley carb,,,, stock.
One owner 69 Camaro,(yep, bought it new)
RS SS Hugger Orange, L88, 4:10's tru-tack posi, ducted hood, Endura, spoilers.
TH400 (CX) with Coan 8" converter, GV-OD, 8 track still on console and best et 10.495, 128.79mph 1.428 60'
All with 1960's stuff. (except tires and converter)
+ MT Super Scavenger headers & 3" full exhaust with X pipe.
1000cfm AED and HD Harold-Lunati SR, 725 lift with shaft rockers too.
http://epitomesrebuild.com/
http://ss427.net/
  #14
Old Dec 2nd, 08, 01:26 PM
l-79s are out there used and chaper than gm. *l-39 not l-79
  #15
Old Dec 2nd, 08, 01:30 PM
Jerry
Isn't an L79 a 327?
69 Z11 03D Van Nuys
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: GM Performance Parts ZZ427/430HP Engine
Location
Location
First Name
Human Verification
