how the heck does a trans brake work???? - Team Camaro Tech
Thread Tools Display Modes
Old Nov 16th, 08, 07:58 PM
dubs68camaro dubs68camaro is offline
Default how the heck does a trans brake work????
Can or should you use them in a street car? Can you decide when and when not to use it? Will they blow up a stock TH400??? Thanks!
I get confused when I watch PINKS! and they say they are leaving on the trans brake. Can they not leave on it??
Old Nov 16th, 08, 08:45 PM
2x67rs/ss 2x67rs/ss is offline
Andy
Default Re: how the heck does a trans brake work????
Yes they can be used on a street car. Most of them change the trans to a manual valve body so it can be a royal pain driving in the city since you have to shift it much like a manual transmission.
The only time you use it is to launch the car at the track. But on some valve bodies you have to hold the button down to get the car in reverse. Again can be a pain because when you are backing the cable tends to wrap around the column while turning the wheel.
I don't think it would blow up a stock 400 but when you release the button it very well could destroy the sprag in the trans depending on the power going thru it.
Yes you can leave with out using the trans brake. But a trans brake will help with reaction times in most cases.
And I need all the help I can get.
Hope this helps clear it up a little.
67 R/S convertible Nantucket blue deluxe interior orig.http://s63.photobucket.com/albums/h152/67ss/The%20pair/
67 rs-ss coupe 565BB-400turbo streetcar/racer project 1.43 60ft 9.683 140.91
http://www.youtube.com/watch?v=LFLC2...eature=channel
Old Nov 16th, 08, 11:08 PM
Old Nov 17th, 08, 03:42 AM
DOUG G DOUG G is offline
That was spam
Anywho, a trans brake locks first and reverse together when you're staged and hit the button. Bring the car up to the RPMs you want (it will not move, and usually on a rev-limiter) release the button when you're ready....car launches.
68 Camaro~LSx
Best to Date....and tuning
1.546 60'
7.132 @ 94.43 660'
11.327 @ 116.79.
RedЯum <-Pics
https://youtu.be/Of8WVNYhR1g <~More here
Old Nov 17th, 08, 06:38 AM
Andy
Originally Posted by DOUG G View Post
That was spam
LOL Yeah that how it works.By the time I answered all the questions I forgot to say how it works. Whe you push the button it sends the fliud thru 1&r at the samr time to "lock" it in place until you release the button so that you can mash the loud pedal without it going anywhere.
Old Nov 17th, 08, 07:08 AM
I have always thought that these were best used on really light cars....just because of the physics involved. Is that the case? When using a transbrake, does the drivetrain weaknesses seem to be in the same places (U-joints, axles.....ect)?? I just don't want to add additional factors to my TH400 that might make it not last as long. Kicking around a bracket car next year to run in the high 11's to low 12's.
Old Nov 17th, 08, 07:14 AM
Everett#2390's Avatar
<Jake-68's rule
Weaknesses will be in the same place, but, with trans in two gears, the rest of the drivetrain is at rest. Release the button, then torque/hit is applied.
Foot brake, drivetrain is in tension, trans brake, drivetrain is not.
Old Nov 17th, 08, 09:33 AM
Wouldn't it be a little safe to say that if you have your drivetrain loading (no transbrake), you would have a little less chance of breaking things? We're talking a motor in the low 400 range at the fly.
I never side step the clutch from a dead stop....I always like a little tension. Would a transbrake be a good comparision to a 4 speed clutch (side steppin')? Better or worse......yes this is the end of my questions!!! lol
Old Nov 17th, 08, 10:17 AM
PowerWindows PowerWindows is offline
Jim
You're dead on. Transbrake allows an automatic car to shock the suspension in much the same way as dropping the clutch at high rpm from a standstill does.
67 Camaro: 454/TH400/4.10 12 bolt. Lots of options: PS/PDB/PW, tilt, tach, gauges and more. K-K + 797-Z...
"Politics is the art of looking for trouble, finding it whether it exists or not, diagnosing it incorrectly and applying the wrong remedy" - Sir Ernest Benn
Old Nov 17th, 08, 10:37 AM
<Jake-68's rule
Yes, one would have a 4500 rpm or higher convertor to "shock" the suspension.
Used to sidestep when I was younger, I got wiser and went Powerglide.
  #11
Old Nov 17th, 08, 02:53 PM
Andy
It would be a little like your clutch but it is a hard hit! I think on a stock tranny the first thing to go would be the sprag or the u-joints.
  #12
Old Nov 17th, 08, 05:17 PM
Badbird's Avatar
Badbird Badbird is offline
Banned
Ron
I always dreamed of running a trans brake, on the street, in a 70 Chevelle SS454 I once had!.....The motor was built to LS6 specs and had a built and beefed up TH350 along with a 12 bolt posi, 4.10 gears.....It was equipped with a 3000 stall converter, would this stall speed would have been enough for a nice launch?
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Transmission & Driveline      Current Topic: how the heck does a trans brake work????
Location
Location
First Name
Human Verification
