| Team Camaro Tech Current Topic: Stamp pad help | ||
| Tag Team De-coding tags and numbers. |
I just bought a 68 rs/ss. I was curious what the stamp on the engine decodes too.
Vo824TJU Any help would be greatly appreciated Thanks Joe |
| Sponsored Links | ||
Advertisement | ||
TJU suffix has two similar applications:
TJU 1973 350 van & bus - 155 4 C-10 to 3500 TJU 1974 350 van & bus - 160 4 C-10 to 3500 Casting number and date would tell you which one it is, but they are basically the same.
Eric 69 'vert project big block/TKO 600 RR 68 'vert driver RS clone -- gone! |
Thanks for the help. I was hoping for more, lol, the manifold on the car was a 68 Z28 hirise 3917610. I need to do more research on this car
Thanks for the help |
I am at a loss on this car, trying to figure out what is going on.
It has the correct z28 manifold and heads but the block is wrong. It has 4 leaf, leaf springs. I am trying to determine the history |
Have you checked out the other model clues on CRG's site? http://www.camaros.org/diffs68.shtml
Does it still have an original tire pressure sticker in the glovebox, and if so what does it read? Is it a 4-speed, and does it have the Muncie speedo cable (exits the firewall to the passenger side of the wiper motor and runs across and down the trans tunnel opening)?? It may just have a bunch of different parts on it that a previous owner installed, and you won't be able to pin much down.
Yes a 4 speed and the speedo cable comes out just to the passeger side but still under the wiper motor
You can see the cable coming out of the firewall then stuck back behind the booster
| Sponsored Links | |
Advertisement | |
