New Slicks - Team Camaro Tech
Old Nov 23rd, 08, 08:57 AM
1fun71 1fun71 is offline
ron
Default New Slicks
I need to get new slicks ,I have a 8"wheel what do you guys think Hoosier-m/ts or Goodyear's they will be 10"wide
Old Nov 23rd, 08, 09:06 AM
Pro-Street69Camaro468 Pro-Street69Camaro468 is offline
Dave C
Default Re: New Slicks
My brother and I always had good luck with good years....
Old Nov 23rd, 08, 09:11 AM
ron
Ok thanks I do have traction problems hope new slicks help
Old Nov 23rd, 08, 09:18 AM
DOUG G DOUG G is offline
RedЯuM
40 Coupe swears by Hoosiers.
MT ET Streets have a good following too.
68 Camaro~ LSx
RedЯum <-Pics
http://www.youtube.com/watch?v=Of8WV...ature=youtu.be <~More here
Old Nov 23rd, 08, 09:42 AM
Cali Z28 Cali Z28 is offline
Scott
Ive had good results with the ET Streets, but the ET Drag with the stiff sidewall worked the best
I would like to try Hoosier, have friends that swear by them
1969 Camaro, 548ci, 10.6:1, solid roller, Ford AOD, 4000 Stall, 12 bolt with 4.11's
New best, 10.59 at 125.48, 1.39 60ft
http://i73.photobucket.com/albums/i2...aroattrack.jpg
Old Nov 23rd, 08, 02:25 PM
Everett#2390's Avatar
<Jake 68's Rule
The only problem(?) with running a 10" wide slick on an 8" wide rim is a true slick will 'balloon' on the top end due to centrifugal force, the tire diameter will grow in the middle of the tread, nothing wrong with it.
The narrower the tire or the wider the rim, the less diameter growth. A normal thing.
I run the size of both and I have a full hand width between the tread and fender. The fender has rub marks.
Give a man a rescued dog for the health of his soul.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
Old Nov 23rd, 08, 05:25 PM
Bad67355 Bad67355 is offline
Mike
I have m/t et drag slicks on an 8" rim and have never had a prob, they are 26x10
http://i264.photobucket.com/albums/i...acing006-1.jpg
67 RS 355sbc 11.76et @ 115mph 1.67 60'
Old Nov 24th, 08, 03:41 AM
<Jake 68's Rule
Different tire construction, I forgot to mention I have Firestone's, now Phoenix, softer and lighter construction, 28.5X10.5X15.
Old Nov 24th, 08, 10:45 PM
hhott71 hhott71 is offline
Tom
10.5 x 28 M/T ET Drags on 8" rims
12 PSI and work well with the slapper bars.
71 Camaro 355 NA
11.1650 @ 119.30
1.5028 60'
