best way to clean and undercoat an old car? - Team Camaro Tech
Camaro Tech General Tech Area
Old Nov 25th, 08, 07:30 PM
darko darko is offline
Darko
Default best way to clean and undercoat an old car?
I have my 67 camaro in my sig completely stripped of all the drivetrain, front clip/subframe and want to go through and clean up the underbody/firewall to make it look nice. I was just wondering if anyone had any good ways about doing this because from the looks of it it will take a while and be pretty sucky. The bottom is all oily and greasy and it has a factory type of undercoating but no rust. Also what do you guys recommend undercoating it with?
1967 Camaro
twin turbo
Old Nov 25th, 08, 07:35 PM
Norcoastal Norcoastal is offline
Steven
Default Re: best way to clean and undercoat an old car?
Oven cleaner and a bucket.
It's a filthy job, but it comes out great.
1968 Rally Sport
Corvette Bronze, 327, M-20 4 Spd
PW, PB, AC, Deluxe Int, Vigilite
Old Nov 25th, 08, 08:08 PM
AlexFolino AlexFolino is offline
Alex Folino
Ill second the oven cleaner.
GM service technician.
25 years old. I only drive chevys. Everything else and i do mean everything can rust in piece.
68 owner-The only way to go
Camaro: A small vicious animal that eats mustangs.
Old Nov 25th, 08, 08:10 PM
Darko
ugh this is gonna suck
1967 Camaro
twin turbo
Old Nov 25th, 08, 08:18 PM
Straight-line-69 Straight-line-69 is offline
Go to Home Depot,..buy a gallon of WD-40, a spray-bottle, a plastic sheet, some nylon gloves, plastic scrapers, and a bag of rags.
Soak the the stuff on day one. Soak it again on day two. On the third day soak again and start removing the gunch. It will be real easy to remove but it's messy.
Good luck!
Old Nov 25th, 08, 08:24 PM
camaroboy1077's Avatar
camaroboy1077 camaroboy1077 is offline
Tech Team
Nygard
just got done doing this and i gotta hand it to the oven cleaner and some good scrubbing i used a scotch brite pad on the real gunky stuff and it worked great. afterwards i used 3M's rubberized underbody that you can buy in spray cans at autozone. works well and feels tough, just make sure to apply in light coats or it takes forever to dry
1975 Camaro Rs "Current project"
1967 Camaro RS "Sittin since 92"
1975 Trans Am 455 "Super Chicken"
1992 Camaro RS "Roxy" daily driver
"do or do not, there is no try"
Old Nov 25th, 08, 09:40 PM
67sc 67sc is offline
Kev
Get a rotisserie and turn it on its side. Then start cleaning. Strangely, I've found that red Brakeclean brake cleaner will loosen the factory rock hard undercoating. Scrape w/ wooden wedges. Then do it again.
Very nasty dirty work, sorry.
Its not just cosmetic. Especially if that car is actually from MI w/o rust, clean the crap out of it and make sure the rust doesn't start!
Old Nov 29th, 08, 10:41 AM
Darko
well got some of it done and i'd have to say the best way is to scrape off as much gunk as you can with a scraper, then a air angle grinder with a wire wheel on it. The factory undercoating on in mostly scraped off with the scraper though...and the wire wheel gets everything off and does a good job of getting into the nooks and crannies
1967 Camaro
twin turbo
Old Nov 29th, 08, 12:30 PM
94camaro5.7 94camaro5.7 is offline
david
i used to sandblast at a monument shop we sandblasted metal all the time if you use a light sand like silica sand it should make it real nice it dont hurt rubber if you dont hold the end of wand on the rubber a cheap used portable sand blaster is worth it
Old Nov 29th, 08, 05:34 PM
Pro-Street69Camaro468 Pro-Street69Camaro468 is online now
Dave C
I like the idea of dw-40 I use this on flange that have a heavy layer of tar on them.I have never tried it on undercoating but it cant hurt,you will need a bunch of degreaser afterwards though.
Old Dec 1st, 08, 04:25 AM
kleptopigdog kleptopigdog is offline
Thumbs up Re: best way to clean and undercoat an old car?
i used a makita grinder with a wire wheel attachment .It went really fast .Be sure to where googles and old clothing .This weekend i'll go back undeneath with a pressure washer .Fine clean it.3m 08883 is a good under coating or duplcolor paintable .Remember some of these product don't dry .If its not paintable it stays in a tar like state .I'm acutually going to use raptor gaurd or gator gaurd bed liner coating on mine .good luck
kleptopigdog.........68 camaro in about a hundred peices
lifes a garden , dig it joe dirt 2001.......
Old Dec 1st, 08, 11:39 AM
chops chops is online now
Greg
It is a suck job, and no matter what you'll get dirty but once you start just go for it.
I used a side grinder with twisted wire cup.
POR 15, then chassis black. With it staying in the garage most of the time, I should be good until about the year 2050 or so.
1969 RS/SS Vert
1031 Engineering llc
Old Dec 1st, 08, 03:59 PM
timnjen07 timnjen07 is offline
Tim
Right or wrong I had a guy sand blast the bottom of my Chevelle and frame. He primed all after and charged 250
Old Dec 1st, 08, 04:12 PM
nikkisdad nikkisdad is offline
mike
I found a good trick after a City tar truck blew a hose next to my truck. That crap was everywhere! I took it into a shop for a estimate to take it off, and it was around 350.00 bucks. Before the estimate the guy done a small spot with RM brand Prepsol cleaner. The tar melted away very fast and it left no residue. I believe this is a little stronger than WD 40, but the idea is to get it off. I went to the paint shop, and bought a gallon and cleaned the truck myself for about 25.00 and a couple of hours.
