GEN 4 front brakes on GEN 2 spindles - Team Camaro Tech
Thread Tools Display Modes
Old Nov 27th, 08, 09:57 AM
txs67bgt txs67bgt is offline
jay musgrove
Default GEN 4 front brakes on GEN 2 spindles
who makes a kit to install gen 4 (1998 Z28 specifically) front disk brakes on gen 2 front spindles. I have a 1998 Z28 donor car that I want to use the entire braking system from, but the ball joint to ball joint distance is to long, because the gen 2 spindle distance is around 7 inches I could use it but would like to keep the factory rotors/calipers.
thanks
JM
Old Nov 27th, 08, 12:01 PM
pdq67 pdq67 is offline
Banned
Default Re: GEN 4 front brakes on GEN 2 spindles
Maybe, just maybe, TSM and ECI as well as M/P can help?? Maybe SSBrakes too?
I flat don't know the newer brake systems like I know the old ones.
Have you checked Doug's ebay custom made brake caliper brackets out??
David L. is Doug here.... http://www.steeltechsolutions.com/
He makes all sorts a brackets!
Good luck w/ your project and please keep us posted on how you do it.
Thanks and have a H/H T-Day!!
pdq67
Old Nov 27th, 08, 04:38 PM
novaderrik novaderrik is offline
i believe Kore3 makes and sells brackets to do just that.
or get all redneck and do it yourself- machine down your rotors into just a hub that fits into the later rotor, stick the calipers over the rotors, and make a bracket template out of cardboard and then transfer it over to 1/4" steel.
that's the reader's digest version of what needs to be done.
you don't plan sincerity.
you have to make it up on the spot.
wanna hear about 20 years ago when i was too smart to know any better?
Old Nov 27th, 08, 10:28 PM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
Scott
thanks
JM
LOL, yeah, those spindles are totally different (on a side note I sold a set of 4th gen hubs & spindles for $50!). Yeah, check out http://www.kore3.com/ for brackets, he might make them. But most guys going to all the trouble of cutting down the spindles & using adapters move on to bigger C5/C6 setups.
For 12" brakes most guys just swap to b-body spindles and 3rd gen 1LE rotors. Works great, very cheap. Search here for a while: http://www.nastyz28.com/forum/forumdisplay.php?f=17
Scott from NJ. Stay thirsty, my friends
Vent Windows Forever! ... My junk ... NastyZ28 ... NJ Camaros & Firebirds
Feather-light suspension, Konis just couldn't hold
I'm so glad I took a look inside your showroom doors
TC Member #13
Old Nov 28th, 08, 02:48 PM
Banned
Fwiw, there is a VERY detailed site SOMEWHERE w/ pic's and all that detail's 1Le and Big Car cast-type 2nd Gen. spindles caliper arms cut off and then modified to mount 13" rotors and caliper baskets.
It's easy and is a He, He!!, "Red-Neck" way a doing it!
Me and my 13" "pdqCBB" front conversion on my 1st Gen.!
Homemade caliper brackets that fit the old big, single piston calipers and they are on my car now.
pdq67
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Brakes, Suspension & Steering      Current Topic: GEN 4 front brakes on GEN 2 spindles
Location
Location
First Name
Human Verification
