| Team Camaro Tech Current Topic: Crossmember / trans install question | ||
When I dismantled my 67 I pulled the 327 and muncie out as on piece. Since the restoration, I have installed the engine with the bellhousing and clutch in the car, mainly to save space in the garage while the trans was being rebuilt. The question I have is: do you bolt the trans up first then install the crossmember or crossmember first then trans? I remember that I could not get the crossmember out after I removed the engine and trans until I removed the front clip...I’m sure the bushings were compacted. Now the front clip is on with new body mounts, hopefully I can get it back in without separating the subframe from the body. I would be concerned about the fenders hitting the doors and scratching the paint.
Any details on this process would be greatly appreciated. |
| Sponsored Links | ||
Advertisement | ||
You can do it any way that you want ! If the body bushings are new, you shouldn't have to touch the subframe bolts.
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1 |
That is great. Thanks!
| Sponsored Links | |
Advertisement | |
